Urban apartment
enricocerica
Not very inspired those times so here is another archviz, will come later on with something else more original, well I hope so.
Edit : As an answer to some of your questions here are some more information
I also add some more closeups exclusively rendered with direct lighting.
Hardware used :
Two GTX580 3GB
Render time :
As always it depends from one image to another but it may varies from 2h to about 5h
Basically I render the images using PMC (with or without protals) as it has a better light convergance for indoor renderings. The image is lit with HDR map.
I tend to render a second image using direct lighting and sun for lighting and I mix them together in postpro. It's very fast, about 10 to 20 min, it is a quick way to add sun over a hdr map and it also help removing some residual noise as direct lighting produces sharp surfaces.
Postprocessing :
To remove residual noise
To combine PMC and direct lighting images
To fix some lighting and contrast and to improve light entering from windows fx
To add CA
I'll try to come later on with some more enhanced information about the workflow.
The making of : http://www.ronenbekerman.com/making-urb ... co-cerica/
Direct lighting only
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
PeterCGS
Exceptional quality as always! I guess its time you did some tutorial DVDs showing your workflow ;)
Very impressed by your wood floors! Are these textures created by you, or are they from some texture collection?
Win7, i7 980 Hexacore, 24GB RAM, 3xEVGA SC 670 GTX 4GB
justix
ouch! ...stop embarassing us all...!! ah ah ah only joking your renders are TOP photorealistic productions and so inspiring to keep
making things better..is this set directlight or? really great :D
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
bakbek
WOW! These are remarkable visuals, regardless of the render engine used ;)
I like the style of the Interior, and that wooden art is lovely! wouldn't mind having such a piece on my wall.
There seems to be too much blurriness in some areas... for example, in the 3rd image, the bookcase could have used some more sharpness... I think.
Would love to know more about the process of making this ;)
Cheers
Ronen
Ronen Bekerman / www.ronenbekerman.com
Tugpsx
Wow very nice
enricocerica
Thanks to all for wiewing and commenting,
I updated the topic with some additional information to answer some of your questions and also added some direct lighting only images.
@bakbek : Now that you point it, indeed the bookcase could have been more sharp ;)
@PeterCGS : I usually use images grabbed over CGTextures.com and stitch them to get a hires texture, then I create the bump and spec maps.
ROUBAL
Not very inspired those times so here is another archviz...
AhAh ! For someone not very inspired, it is very impressive ! Great works, as always ! ;)
evo
excellent works and thank for the postpro. skils, very intresting
Intel Core i7 920 @ 2.67GHz, 6.00 GB, 896 MBGeForce GTX 260 (x2), Windows
RIBS_stairs
http://www.refractivesoftware.com/forum ... =5&t=17973
Elvissuperstar007
shoes for Bigfoot
enricocerica
Thanks to all,
@Roubal : Well archviz is not my favorite area and as long as you see archviz from me this means that I'm out of inspiration ;) But I really enjoy doing this one.
@Elvissuperstar007 : Well pointed ! I checked in my scene, the shoes are not so big but considering that the chair is a bit small, all in all indeed, big foot is not so far :?
