Display Problem after reinstallation
Murd0ck
i worked a long time without big problem with Octane Render.
But after a Virus kicked my Windows i had to reinstall all my Programs
and now i can´t render my Project as well as before...
There are empty Polygons....my english isn´t good enough to explain it...
so here comes the image.... ;)
i7 - 3820 @4,4Ghz | 2x GTX770 4Gb + 1x GTX 780TI 3Gb | Win10 64 Bit | 16Gb Ram
roeland
Try if you can export only triangles, and make sure the geometry is imported at the correct scale.
Roeland
Murd0ck
What is the correct scale?
In the C4D Plugin is meters and in Octane too.
I rendered this Object multiple times before reinstall without
export only triangles....
Hi, could you post a simple scene in c4d format? i try to look at it if you want ;)
ciao beppe
Murd0ck
Murd0ck
my result -.-
here is mine, the scale is correct, it seems that your obj exportation is broken :roll:
have you already tried to overwrite the c4d to octane exporter 11c?
ciao beppe
Murd0ck
i´m using Exporter 11c....hm...this sucks
Have to Render some Buildings to next week...
Murd0ck
When i zoom in some more Polygons get visible and when i zoom out they get
invisible again
Murd0ck
works with "OctaneRender® 1.0 beta2.52"
