Support for forestpack?
jan kudelasek
Hi Karba,
could it be possible in future?
Thanks a lot.
Jan
W7 / Quad Core Xeon E5405 / 24G / Asus ENGTX 480, 580 / http://www.allcity.cz / https://www.facebook.com/pages/Allcity/ ... e=bookmark
MaTtY631990
2D and 3D trees are possible with octane render. The materials for 2D trees have to be set up manually. The texture maps for both diffuse colour and alpha are located in the installation directory in folder named maps.
Karba
jan kudelasek wrote:Hi Karba,
Thanks a lot.
Jan
For me It would be much easier to make MultiScatter support in future. Just because I am the developer of MultiScatter.
andrian
Thanks a lot.
Jan
Yes please!!!
Vista 64 , 2x Xeon 5440 - 24GB RAM, 1x GTX 260 & I7 3930 water cooled - 32GB RAM, 1 x GTX 480+ 1x8800 GTS 512
CGsociety gallery
My portfolio
My portfolio2 - under construction
Web site
Making of : pool scene - part1
gabrielefx
Thanks a lot.
Jan
it works, I use Forest Pack Pro. Octane renderize only what you see in the viewport.
When Octane will translate Max instances everything will change.
I'm sure that Karba will develop an optimized Multiscatter version for Octane.
jan kudelasek
thank you! Can´t wait :)
All the best
Jan
ba2ra
Karba "MultiScatter" a very useful tool, it would be great to use this opportunity!
(Karba " MultiScatter" очень полезный инструмент, было бы здорово использовать его возможности!)
W7 Pro 64bit | i7 980 @ 3.33GHz |GTX580 |GTX 275|24Gb DDR3
User avatar (Default)
merid888
hi gabrielefx, how you did to work forest into octane ? becouse i can't, i have the forestpackpro too and i can't see nothing
do you have some image to see the steps how works ?
thank you
mbetke
I use Forestpack Pro with Maxwell for example and use the Forestpack Instance tool with a Maxwell Proxy.
If Octane will not support proxies combined with instances then your viewport will get slow like hell even with box display.
Until now Forest also works with OCtane the same way. Only that my system cant go over 13 millions polygones before render fails.
Plus I hope Karba will not slow down a possible support for forestpack only because he is a developer of a competitors tool.
PURE3D Visualisierungen
Sys: Intel Core i9-12900K, 128GB RAM, 2x 4090 RTX, Windows 11 Pro x64, 3ds Max 2024.2
Return to “Autodesk 3Ds Max”
