Using EXR format in Octane Render
JamieLewis
Hello everybody!
I encountered with the problem in Octane. The problem is - how I can use EXR format? I mean the way of exporting scenes or images with applying Z-Depth, and different channels. I need it to use in Nuke.
Thanks in advance, guys!
face
When you mean packed exr.
Because you can only render one channel in a given time, you can also not pack different channels into one exr.
face
http://vimeo.com/user2509578
JamieLewis
So, how I can use it? Could you give an example of using it? Or probably you have manual of using exr.
face
You can save only one channel to one exr.
Render with one kernel, save the exr, change the kernel to whatever, render and save the next exr.
To save as exr you must click on the save render to image file button on the top of the render panel, 3 icons left the lock button.
face
JamieLewis
And could I set the light reflection of the shadow it has separate channels?
face
There is no shadow pass.
Read the manual and you will see the channels which are supported.
face
Return to “Commercial Product News & Releases (Download here)”
