Wrong orintation on ICE particle instance
Jack-Jack
Hi all,
I have made some tests with ICE particle instance and each time the particle instance have wrong orientation in Octane render.
How it is possible to correct it?
Especially important for mbFeatherTools (Michael Buettner).
Best regards!
Win7 x64, 12GB Ram, i7 970 3,2 GHz,
GTX590 3GB
Softimage 2013 & Octane 1.025 beta 2.57
Soft2Octane v1.0252c Win
face
Yes, i can confirm it.
Can you try this dll?
Make a copy from the old dll and copy the new one in the addon folder.
face
Octane2011.zip
(182.31 KiB) Downloaded 369 times
http://vimeo.com/user2509578
Jack-Jack
Thanks face, I will try it!
GTX590 3GB
Jack-Jack
Hi!
I have made some tests with new dll and it's still works not correctly.
With new dll particle have global wrong orientation (opposite direction).
Roman
Octane new dll
Octane new dll
Octane old dll
Octane old dll
Mental Ray
Mental Ray
GTX590 3GB
face
Thanks for feedback, have only test it on y=0.
Will try it again...
face
Jack-Jack
Thanks face for the answer.
I hope in the future the given problem will be solved :)
Octane is the best!!!
Roman
GTX590 3GB
face
Next try, this should work...
face
Octane2011.zip
(182.08 KiB) Downloaded 448 times
Jack-Jack
Hi!
It works correctly now, for my previous test :), thanks face!!!
But, i have made some new test with simple ICE scatter, and particle orientation wrong again, if align to normals.
If no align to normals, it works correctly.
I have attached pictures and a simple scene.
Thanks face for your work and patience! :)
Roman
Scattering.rar
(1.56 KiB) Downloaded 371 times
Octane
Octane
Mental Ray
Mental Ray
GTX590 3GB
Jack-Jack
Well, I hope in the next version of Soft2Octane a problem with particle instance orientation will be solved :)
Octane is the best!!! ;)
Best regards!
Roman
GTX590 3GB
wilson66
i have also the problem that the particles have a wrong orientation. also using the new dll, but in xsi 2013 and octane 2.58e
here is an image...
how to solve this?
Return to “Autodesk Softimage XSI”
