hi there,
exported as obj from poser into octane.
when I import the eyes are completely black and when I assign a texture see left eye, it seems to be not positioned correctly?
you can see my texture settings there
can anyone help???
thanks in advance!!
Help black eyes export from Poser
- teecee2107
You have a material called 'eye sufrace' that is diffuse with opacity set to maximum. Try to change this material to specular, lower the opacity a bit and increase the index a little bit. That should look much better.
Another thing to try, make it portal and set tears to specular. Compare the results.
