Hello everyone I am new to Octane Render. I was wondering if someone could help me if possible. I created a house model in ArchiCAD 14 and exported to
Artlantis 4.0 to add really nice plants and other objects. Does any one know a procedure to export from Artlantis to Octane Render (OR).
I do know OR reads obj files but my exported file isn't capable of being read, OR simply closes. So I can only assume that
OR does not support obj files exported from Artlantis
Exporting Procedure
Roeland,
I had to send you a different file because I think there is a limit on the file size even as a zip. My original
zip file was 20.4 mb so it wouldn't attach. I have attach a very simple model. Your help would be greatly
appreciated.
appreciated.
- or.zip
- (186.53 KiB) Downloaded 240 times
Rouland,
When opening the file, simply says file error. Octane does not close remains open.
I do have the latest nvidia drivers for the gtx 500 series. I did download
the test files from the website and even those give me a file error
My current set up
Windows 7 ultimate 64 bit
i7 2600k
Msi gtx 560 (1gb vram)
16gb ddr3 corsair
Asus P8Z68 -V motherboard
My current set up
i7 2600k
16gb ddr3 corsair
does the pathname where your file(s) are contain special (non-ascii) characters by any chance? octane doesn't like that. if that is the case something like c:\test\mesh.obj should work...
„The obvious is that which is never seen until someone expresses it simply ‟
Hello,
My file path does not have any special (non ascii) characters. As I mentioned before, I downloaded
the sample scenes from the website and those have same issue with file error. If I can manage to
open an artlantis exported obj file and correct this error I will on the spot purchase the full version
the file renders also on my system without problems; what error message do you get if you try to open the file?
