Render frame window doesn't correspond to size in output
roccodiablo
Hi there
I'm using octane for 3ds max. When I specify the output size in the common tab, the render frame window for Octane doesn't change. I want to render 2400x1200 px but the largest it will go is the size of my screen.
The only time the settings in the common tab work is when I first open max. If I set the render frame window to be 320x240 say, it'll work, but if I want to change the size again it doesn't - it stays at 320x240
Any ideas why this is happening?
thank you
Return to “Autodesk 3Ds Max”
