OctaneRender® 1.0 beta2.52 >>> download here <<< [OBSOLETE]
uzer_name
Centos5.3x64 with CUDA 4.0.17 (GTX570) - beta 2.57 starting but not rendering
maybe render 1st pass, and stopping
CUDA device 0: KERNEL FAILED!!!
when i try to move sun location in "daylight" panel - it gives:
CUDA device 0: Not enough memory to allocate buffer of 136 bytes for texture 19
CUDA device 0: Could not update sun data
2xXeon5160@3Ghz , 16Gb RAM, Zotac GTX570, PNY QuadroFX5500, Centos5.3
roeland
Does it happen on any scene you try to load? Does it happen when you try to render a material on the material ball?
Roeland
uzer_name
it happens on any scene and/or any material with empty scene.
Actually cuda-enabled applications works (for example OptiX and CUDA_SDK demos runs ok)
roeland
If you go to preferences → CUDA Devices, what are the numbers shown under Device Memory Usage for your graphics cards? And which are used for rendering?
Roeland
uzer_name
GTX570, because Quadro FX 5500 not CUDA-capable.
all data (ram size, cores qty ) seems correct
Sometimes octane renders 1 st pass and stops with CUDA error.
Also, shows 0 Tris in status line
PS. Oops. when i starting up empty scene - Memory bar in Prefs show 1400 meg (ram size of GTX570), but when i try to render anything (material ball, or just move environment texture color slider) - ram shows just 57meg, and gives error
"CUDA device 0: Not enough memory to allocate buffer of 160 bytes for texture 16"
roeland
What is your NVidia driver version? Here it works on CentOS 5.5 with driver version 290.10.
Note that if you update the driver, you then need to reinstall the CUDA toolkit.
Roeland
uzer_name
Thnx, with 290.10 it works (before i had installed 275.xx and 280.13 - doesnt works).
Return to “Commercial Product News & Releases (Download here)”
