Barn Conversion
sdwhitton
Hi there
I just used the glass material in the online database... and then just found out that if you double click on this, you can tweak it..
Like in Vray, I model my glass as a box, 7mm thick or so, so it doesn't get too 'refractive'
But you have to use path-tracing to render this, as far as I'm aware
I think if you want to use the quicker direct-lighting renderer, then to get the transparency, you use a glossy material, black I assume, make it very 'specular' and not very 'rough' and bring
it's opacity down, but others will know better as I'm a novice!
cheers
Stevo
workstation well past its sell-by-date, Vista 64 bit (!) with a pitiful amount of RAM, re-invigorated with a GX 590
3ds Max Design 2011 (have 2013 but can't be bothered to re-do all the UI), CS5, and that free z-brush program, whatever it's called
Return to “Works In Progress”
