Bathroom (texture environment)
adiarc
"Said,
you should try rendering 2x-4x the final size with less maxsamples and then scale down.
The result is quicker and better.
Karol"
What does scaling down mean, simply reducing the size e.g. in Gimp? I tried this on a noisy render but it doesn't make any difference... What's the trick here? :?
said
Hello adiarc,
this is a quick tutorial how to reduce the noise in your image :)
http://www.refractivesoftware.com/forum ... f=21&t=878
i hope it will help you ;)
greeting
said
Windows 7 64bit
i7 2600k 3,5 GHz
Asus GTX 570
16GB DDR 3
Archicad 15____Cinema 4D R13______3Ds Max 2011_____Octane for 3Ds Max
KaroBastardKiter
correct
if you want to render a picture 1200x768 then render 3600x2304 with, say, 1000-1500 samples and then scale it down to 1200x768 in gimp. You'll see the noise clears off and the image is much much sharper
Alienware M17x R3 | GTX 460M | Quad 2.0 GHz | 8 GB
Win 7 x64 | Blender 2.59 | Octane
adiarc
Thanks said and KaroBastardKiter, I will check it out. :)
Return to “Works In Progress”
