Can anyone donate an OCS file with simple sss setup?
I'm having a hard time finding the correct method to make SSS work. I've seen the tutorial by Roeland, and while it helps a little there's still a few things about it I'm not understanding. Roeland(or anyone), can you share a scene with a simple object and the SSS effect applied to a diffuse material, so that I can look at the connections in the tree?
Ryzen 5950x
128GB Ram
RTX 3070 x 3
128GB Ram
RTX 3070 x 3
i did something like that. don't know, if it is really useful, as noone responded, but her you go:adrencg wrote:I'm having a hard time finding the correct method to make SSS work. I've seen the tutorial by Roeland, and while it helps a little there's still a few things about it I'm not understanding. Roeland(or anyone), can you share a scene with a simple object and the SSS effect applied to a diffuse material, so that I can look at the connections in the tree?
http://refractivesoftware.com/forum/vie ... 419#p70419
„The obvious is that which is never seen until someone expresses it simply ‟
