bump height
t_3
question: what does a "1" for a bump texture means in terms of height? e.g. if set to maximum, the (faked) difference between 0% - 50% - 100% would be what in meters/micron/parsec & absolute or relative to what?
i also haven't found infos on how bumpmaps are treatened. commonly 0% (black) means maximum inset, 50% (grey) means no displacement, 100% (white) means fully embossed - is this true for octane?
gabrielefx
t_3 wrote:question: what does a "1" for a bump texture means in terms of height? e.g. if set to maximum, the (faked) difference between 0% - 50% - 100% would be what in meters/micron/parsec & absolute or relative to what?
use the multiply texture node, the first value will adjust the bump.
Unfortunately Octane doesn't have an option to blur the texture.
t_3
thanks for taking this up ;) i of course use several methods to adjust bumps, where a map mix node is one of them. i am just keen to know if there is a metrical analogy for the bump values, so it would be possible to adjust bump values not only by taste, but by real numbers; i.e. having a cylinder with radius = 10cm, a bump (or normal) map set to 1 fakes another max. ?cm/mm to the radius...
btw; somewhere in the forum i found a post saying, that octane treats bump maps "reverse"; means that black extrudes the surface...
and you're right; some math nodes (like matrix filter functions and just simple mathematical functions like add/subtract/multiply/divide) would be nice additions to the node system....
