License Activation
Ian.Kidston
Hi team,
Having previously installed and activated 3dsMax v1.0 beta 2.56, I downloaded and installed the current 2.56b version. Rebooted Computer. The plugin is no longer activated. When I attempt to activate I get an error message which notes that:
"This account is currently activated on another machine. Please deactivate it on the other machine first and wait 30 minutes befor re-activating it on this machine, or activate another account/license on this machine."
Ian
roeland
What happens if you deactivate the license and then reactivate? You can deactivate from within your customer area.
Roeland
Ian.Kidston
roeland wrote:What happens if you deactivate the license and then reactivate? You can deactivate from within your customer area.
Roeland
Thanks Roeland,
I have deactivated in my account (hadn't noticed the deactivate button previously) - will leave it an hour or so and try to reactivate. Will report back.
Ian
Ian.Kidston
Still unable to activate account for 3dsMax.
Having deactivated the account over two hours ago, I now get the message to activate the account when Max opens. Fill in the correct detail into the dialog box - error message:
"Invalid OctaneLive account or wrong account / password combination"
I have tried both copy and paste and typing the password - same error in both instances.
What next?
Ian.Kidston
Activation is still dead as a dodo.
There seems to be a problem with the licence server on your end.
Copy of part of email sent yesterday below.
I checked my OctaneLive account a few hours ago, with a view of attempting to activate the updated plugin, and to confirm that the Max Plugin account was still deactivated from yesterday. I was surprised to see that it was once again active. I opened up Max but got the error message that it was active on another computer (same problem from yesterday). I went back into the OctaneLive account info and deactivated the account. All appeared to be OK. Prior to opening Max I rechecked the account a few minutes ago and once again, the account it active.
Is there anyway you can reset the account at your end?
roeland
Ian.Kidston wrote:Activation is still dead as a dodo.
I will send you a PM
Roeland
Ian.Kidston
Roeland
Will await the PM
Ian
Ian.Kidston
Thanks for sorting it out, all good now.
Return to “Autodesk 3Ds Max”
