Hello guys,
I'm preparing the next episode of my series.
Featuring for example an Abarth.
Any comments welcome !
One thing i don't understand well.
With the first one, the hdri file is 35 Mo
With the second one, the hdri file is 195 Mo and not bright as the first one.
Is it because the memory, right ?
This mean that i can't go out the brown line ?
What means the three numbers ?
Thx
Niuqcam
http://niuqcam.blogspot.com/
Fiat 500 Abarth
599.8MB used from available 707MB from a card which has 1471MB.niuq.cam wrote:Hello guys,
With the first one, the hdri file is 35 Mo With the second one, the hdri file is 195 Mo and not bright as the first one. Is it because the memory, right ?
Thx
Niuqcam
That means, that you have used nearly 750MB for other applications like Photoshop, Windows Aero...
face
http://vimeo.com/user2509578
Okay. Thank you Face.
A good idea for sufficient use of any gpu renderer, is to use another card for system display and save the memory/gpu power for your renderer.
http://www.OctanePowerTools.com
Octane Render Power Tools, Animation Tools for Octane Render
facebook | YouTube
Intel Core i7 920 @ 2.67GHz - RAM 12.0 GB
Asus P6T7 WS SuperComputer GTX 480
facebook | YouTube
Hello hmk,
Is it cinema 4d supported with your tools ?
Niuq
Niuq
Not yet, will be supporting it soon though, check the FAQ section.niuq.cam wrote:Hello hmk,
Niuq
facebook | YouTube
facebook | YouTube
Octane power tools for cinema 4d... What's up ?!
I think it looks like you have sli enabled which always consumes half my available memory. And also isn't as fast as having them running individually.
If so that may help you out a good bit, if not, then all the other comments here may give you a hand.
Now,everything is allright. Three cards run enough fast for me at this moment...DayVids wrote:I think it looks like you have sli enabled which always consumes half my available memory. And also isn't as fast as having them running individually.
I thought Octane power tools allowing not to voxelise, etc... each frame.
What's up with a version for C4D ?
Niuq.
