Using medium nodes
Forums: Using medium nodes
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
Re: Using medium nodes
Postby MattRM » Tue Dec 27, 2011 1:23 pm
MattRM Tue Dec 27, 2011 1:23 pm
Hello all,
I can't find the volume emission node ? somebody can help me please ?
Matt
MattRM
Postby roeland » Wed Dec 28, 2011 6:03 am
roeland Wed Dec 28, 2011 6:03 am
You can use the same types of emission node as you would use for a regular emitter.
Roeland
roeland
Postby MattRM » Wed Dec 28, 2011 11:10 am
MattRM Wed Dec 28, 2011 11:10 am
Ok I found, I'm not understood that it was on the scattering node with specular material. I tried with and without emissive and I found without emitter, I had better result without emitter.
Here some 30 min test, using the same setup I used in renderman for volume ( frustrum box that never cut orign of camera ) :
In all ways, it's a good trick, but it'll be better with a real raymarcher to had shadows in the volume. But for my current project it's just what I need.
Thank you for help
Matthieu
MattRM
Postby gabrielefx » Wed Dec 28, 2011 4:44 pm
gabrielefx Wed Dec 28, 2011 4:44 pm
wow!...
realistic fog
why objects don't occlude the fog?
gabrielefx
Postby MattRM » Wed Dec 28, 2011 5:11 pm
MattRM Wed Dec 28, 2011 5:11 pm
Hi gabrielefx,
This fog was made by using in a "wrong way" a subsurface scattering function, so algorythm for SSS and raymarching have some differences, the rays not take the same path. I think this is why, I can't obtain the shadows in the volume, or maybe it's the scale of the scene. I'll try other idea to see if I can have better result, but I had the shadows from the cone, whose hide a part of my emitter so maybe is just a problem of setup.
Matt
MattRM
Postby t_3 » Wed Dec 28, 2011 7:35 pm
t_3 Wed Dec 28, 2011 7:35 pm
wow! that looks pretty amazing :shock:
i must admit, i don't understand how you have done that. would you mind posting the setup or maybe even the scene?!?
t_3
Postby MattRM » Thu Dec 29, 2011 1:30 pm
MattRM Thu Dec 29, 2011 1:30 pm
Hi all,
So, in attachment, a scene file, whose contain the setup I used. The most important is the scale of the scene, intensity of emitters and the scale of the scattering node, that determine the density of fog. To much density, the scene turn to black, cause to much absorbtion by the volume. You need to change scale of scattering by scene. if you unplugged the mix node, from scattering you will have a uniform fog. Be carefull, to bounding box your volume fog to never cut it with the camera plane, the camera need to be always out of the box. One setup is to use, a box that match your frustrum camera, more easier setup.
I put also a screenshot from my maya setup, and result from the octane scene.
Enjoy !!!
Matthieu
http://mattrm.blogs.3dvf.com/
MattRM
Postby p3taoctane » Thu Dec 29, 2011 3:19 pm
p3taoctane Thu Dec 29, 2011 3:19 pm
Thanks for sharing... must try this. The megaupload says the scene is unavailable.
At your convenience would you mind re-posting it
Peter
p3taoctane
Postby MattRM » Thu Dec 29, 2011 3:35 pm
MattRM Thu Dec 29, 2011 3:35 pm
Humm, yes, this is strange, but new link here :
Matthieu
MattRM
Postby p3taoctane » Thu Dec 29, 2011 3:46 pm
p3taoctane Thu Dec 29, 2011 3:46 pm
That did it. Many thanks
Enjoyed your blog
Will let you know if I create anything with the fog technique
p3taoctane
PreviousNext
Return to Resources and Sharing
Sat Aug 08, 2020 2:24 am [ UTC ]
