Hi Radiance and all
By any chance will you add a 360 degree flight path for batch processing renders. The idea is a to make multi view image set for 3d online products without the need of real 3d itself.
A simple cicular path/ how many images and distance from axis outer radius setting with batch file location with incrementing namesoffileXX.jpg/png etc would do it. (say that ten times)
or/and add a 360 degree horizontel and vertical with nameoffile-H-xx.jpg/png for horizontel and nameoffile-V-xx.jpg/png for vertical batch renders.
It would allow for a complete at any angle view of any scene quickly and easily for web use.
Hope this is added within octane as a node.
camera pathing
- gpu-renderer
i7 920 2.66ghz quad core, gtx 285, asus p6t, 6gb OCZ 1600mhz ram, Windows 7 64bit ultimate. Nvidia cuda Driver v3 Nvidia display drivers V193.13. Octane beta 2
You are basically asking for a QTVR node, right ?
It must be easy to implement, its just multiple camera angles merged
http://Kuto.ch - Samuel Zeller - Freelance 3D Generalist and Graphic designer from Switzerland
- gpu-renderer
no panoramic mode (but that would be cool to for virtual 3d tours)
But yes key frame animation for objects would be welcomed.
Would you allow a x, y, z format you can type in. Just so people can position the camera where they want. Or can this be done right now.
thanks
thanks
yeah, just look at the pos, target and up float3 nodes connected to the camera.gpu-renderer wrote:no panoramic mode (but that would be cool to for virtual 3d tours)
thanks
You can dial in a camera position there.
Radiance
