failed gtx device
tsolmon_0822
i have 2 gtx 580 and while rendering failed once device. what is this error
t_3
tsolmon_0822 wrote:i have 2 gtx 580 and while rendering failed once device. what is this error
as this question arises every now and then, you may search the forum. i'll make a post about possible reasons (as far as known) later...
tsolmon_0822
tnx. i found answer from help topic pdf. its about the multiple gpu device. if u have 2device on for windows other for octane. thats why..... kkk
gabrielefx
try to disable the watchdog timer.
t_3
gabrielefx wrote:try to disable the watchdog timer.
... can you explain that? i'm currently writing together a post about this problem and possible solutions, but "watchdog timer disabling" is new to me ;)
CoCo
Hi, I just had the same problem on a render (actually I got it twice).
But the difference is that I only have one GPU (580). The scene I'm rendering is not that heavy and the memory is far from being saturated.
The problem occurred approximately after 10-15 hours rendering : I let octane render all night and it was still running fine this morning, but after having used the computer (mostly surfing using firefox) I noticed the engine didn't response any more and saw the (failed) label.
Any ideas ?
Nicolas Wirrmann | Product Designer | Allegorithmic
http://www.allegorithmic.com
http://www.nicolasw.com
t_3
CoCo wrote:Hi, I just had the same problem on a render (actually I got it twice).
Any ideas ?
can you check this?
http://blog.mozilla.com/joe/2010/11/10/ ... eleration/
CoCo
It shows :
Direct2D enabled: true
DirectWrite enabled: true (6.1.7601.17563)
I'm currently rendering and surfing, the GPU has not failed yet.
Return to “Commercial Product News & Releases (Download here)”
