SSS 2.55Tests
- telemmaite
- telemmaite
Ofcourse.It is a material Mix. The SSS is with the Specular material. It appears that SSS is working only with Specular materials changing the SSS values on a Diffuse material has no result for me...It even does not update the view port on changes.
i5 2500K 4.7Ghz | Ram 4GB 1600mhz Kingston | Palit GTX 470 | Win7 64x | Octane with Blender 2.59
- telemmaite
Thanks for sharing your settings, that will help a lot !
Win Vista Integral x64 | 2 x GTX 460 | Quad 2,4 GHz | 8 GB
- Jaberwocky
Thanks for the settings Telemmaite
I was fighting a loosing battle with my candle earlier today.
I got you email by the way.
Cheers
Jabba
Cheers
Jabba
- Jaberwocky
I tried telemmaite's mix of diffused and specular.
There's certainly a lot more control using it.
Thanks once again for the suggestion telemmaite
- telemmaite
You can do it a lot better. Try my second example of the Wax. Without the Specular material and mix. Use Diffuse SSS by putting float texture to the transmission input of the Diffuse material. Then you can increase the SSS by lowering the Scale.It is very important that you have correct Scale of your model. My candle is 6cm wide at top and 9cm wide at bottom, Height 12cm . I have the same candle sitting next to me i can lit it and take a picture with the camera to post it here but the result is nearly 100% the same as the render.
- Jaberwocky
Ok thanks telemmaite
I'll try diffused SSS and adjust the scale.See how that pans out.
