I open up an ocs file. Everything is fine, importing, voxeling.
Then I simply want to exchange the obj and load (replace) the mesh.
It voxels forever and the system freezes.
I gonna try different Nvidia drivers now but would be happy for any ideas to solve this fast.
Thank you.
Refracty
When I reload an obj Octane voxels forever and system freeze
voxeling is done via cpu, or am i wrong? must be something within the object data then (and can't be a driver thing); new 2.55 verison? have you already sucesfully used the mesh you try to load?Refracty wrote:Hi,
Thank you.
Refracty
„The obvious is that which is never seen until someone expresses it simply ‟
Thanks t_3,
it is really weired, because I have successfully loaded the scene (inkl the mesh) and used it. Then I reload and it freezes.
I am using the stable 2.52 Version.
This problem appeared after restoring my system from a crashed SSD to a HDD, but I don't know how this could be related.
"... from a crashed ssd ..." corrupted data - most probably. i have my own experiences with failing ssds and none of them was very pleasantRefracty wrote:Thanks t_3,
