Hello,
When i setup a scene in Blender with multiple lights, all these lights have disappeared in octane.
And i am just left with the environment lamp in octane.
Does anybody have any ideas?
Lights in octane
Maybe because Octane can´t import lights?
face
face
http://vimeo.com/user2509578
- Jaberwocky
vandijkjacques wrote:Hello,
You need to make some mesh lights in Blender.
They will export along with your scene.
Then assign them as blackbody emitters in Octane.
Make sure the scale is correct though.Its critical that the size is not outlandish.IE 600mtr high ceilings for example of they wont work.
also once the light mesh's are in Octane you could also assign them as IES lights using a profile if you need some accuracy.
Hope that helps.
The Jaba
- vandijkjacques
Hi Jaba,
That’s a good suggestion.
I did notice the mentioning of the ies files in the manual.
The manual does however not explain what to do with the ies files.
To bad, it looks promising.
I like Octane, but it needs a good manual.
- Jaberwocky
vandijkjacques wrote:Hi Jaba,
That’s a good suggestion.![]()
take a look at the attached link
http://www.refractivesoftware.com/forum ... &start=100
I put an entry into that page with a screen grab of where to put the IES file
the Jabba
Is there a way of hiding the mesh light/emmiter from the camera (while still casting rays)..?
Just got Octane full today (for use with blender)..thank you
http://www.Neil-Isted.com
Intel i7 870/2.93 GHz
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
OctaneRender™ for Blender
Ds pro
OR Standalone V4
Poser Plugin
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
To set the opacity to 0 should make the emitter invisible.
face
face
Getting use to a new GUI/app can make the most simple things seem confusing
Apprieciate you taking the time to help, thank you
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
