I have a problem with the Exporter after updating Rhino5WIP today. The problem is that with my big scene the save obj dialog does not show up.
Somebody else working with Rh5 with the same problem with heavy scenes (bigger then 1GB)?
Problem with the exporter after Rhino5WIP update
I haven't updated to the latest Rhino Beta due to the crash issues it introduced when loading T-Splines and the unhanded exceptions from the errant RhinoSplash.dll. When they get that sorted out I will give it a try.
Sam
Sam
Win 7 64bit | 2x GTX 285 | i7 920 | ASUS P6T Deluxe | 12GB
Thank you for the fast reply Sam.
Do you know if I can remove the last update?
Or do you think when I reinstall Rh5 WIP from the official website it will contain the last beta?
I am a bit afraid that Rhino will expire if I am not updating.
All right, I have checked the actual betas of Rhino5 WIP and I can confirm that the recent betas after beta Oct-04 2011 cause problems with the exporter (at least with big scenes).
I will forward that to the Mcneel Support so that they hopefully will fix it for upcomming betas.
Those of you who made the same experience should use beta Oct-04 2011 untill things are fixed or the implemented Rhino Plug in will be released.
Refracty
Refracty
