=Octane Tutorial Series= 44 Videos 2017 - Minor Update
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
User avatar (Default)
merid888
hi radiant, i been done all about your tutorial light and just looks like your ies, i been used an erco lights and appear like in the image, could you told me the reason ? i add material
thank you
seetings of materials
image done with ies
image done with ies
radiant
merid888 wrote:hi radiant, i been done all about your tutorial light and just looks like your ies, i been used an erco lights and appear like in the image, could you told me the reason ? i add material
thank you
Sorry i don't understand what your problem is.
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
gabrielefx
thank you
add ies in Octane is not simple.
For example in my scene I have several mesh discs (8cm diameter). I imported them and added the ies photometric. I have not achieved the desired result.
I think that Octane transform the ies curve in a flat texture but ies has three dimensional datas.
Or I have to add on every disc a different material....and in my scene there are 50 discs...
merid888
hi radiant my problem is the ies i can't see the light like yours, i mean, none light just a slow brigth
i been put a lot ies and is the same result, maybe an tutorial with a scene will be better, becouse box and gems without roof isn't the same or some explanation to understand more this topic about ies ?
regards
roeland
Hi gabrielefx and merid888,
What are the settings for your emitters? Are you adding the IES data to the correct pin (i.e. the distribution pin) ? Or can you post a screenshot of your settings and rendered image?
Roeland
merid888
hi roeland i add set image are the same step following the tutorial by radiant
setting ies
setting ies
roeland
Those settings look correct, what does it look like in your scene?
Roeland
merid888
hi roeland the ies arc in the scene, is the problem, i can't see that arc like a ies should be, i see just a ligh piece not form an ies, i been moved all parameters and just looks a light more and less but never an arc ies
i add image, i hope you can helpe understanding this step of the ies light
ies arc, i can't see it
roeland
The shape of the emission depends on the IES file you're using, can you attach the one from your scene? And those arcs are produced if the light is some distance from the wall.
Roeland
bedslouki
Thanks A Lot Radiant !! Amazing Job ! :D
Win 7 Utimate x64 | Dual Xeon 5620 Overclocked 4.2 Ghz | x2 Nvidia GTX 580 Hawk Edition 3GB Overclocked | 96 GB Ram | 3ds Max Design 2013 | Octane 1.0
Return to “Resources and Sharing”
