OCM EXPORTER
Forums: OCM EXPORTER
OCM EXPORTER
Postby Interfaces » Fri Oct 07, 2011 11:47 am
Interfaces Fri Oct 07, 2011 11:47 am
TIG thank you for this plugin, it works fine, but it would add a function to export all views of the scene
Interfaces
Re: OCM EXPORTER
Postby TIG » Fri Oct 07, 2011 2:36 pm
TIG Fri Oct 07, 2011 2:36 pm
I'm not sure I understand the question :?
A Scene only has one view associated with it.
A SKP might have several Scenes that you need to process in turn...
It does export the scene's view as the 'camera' data
    Menu File > Octane OCM Export... > Camera
    or Ruby Console type: OctaneOCM::Camera.export
    If options are available a dialog opens and you can choose from
    <Current_View>, <Current_Scene> or any other Scene tab-name listed.
    It exports the camera data from the SKP Scene into an OCM file
    suitable to import into an Octane OCS. The file is saved with the model.
    It is named thus "../ModelName[Camera_SceneName].ocm".
    Spaces and Non-ASCII characters are made into '_' in Model/Scene names.
    It includes:-
    eye [pos] [as xyz]
    target [as xyz]
    up [as xyz]
    fov [degrees]
It also can export the scene's 'sun' data
    Menu File > Octane OCM Export... > Sun
    or Ruby Console type: OctaneOCM::Sun.export
    It exports the sun data from the SKP Scene into an OCM file
    It is named thus "../ModelName[Sun_SceneName].ocm".
    It includes:-
    sundir [vector]
    longitude [degrees]
    latitude [degrees]
    day [1-31]
    month [1-12]
    hour [0-24.000]
    gmtoffset [0-24]
    northoffset [0-1.0, i.e. North-angle as proportion of 360]
You can then import those as nodes in an existing OCS file...
TIG
TIG
Re: OCM EXPORTER
Postby Interfaces » Tue Oct 11, 2011 5:54 am
Interfaces Tue Oct 11, 2011 5:54 am
OK TIG, thank you for your answer, you know the plug in "render octane power tools" if you know what he is working with sketchup?
will see the site http://www.octanepowertools.com/
Tell me what you think?
Interfaces
Re: OCM EXPORTER
Postby TIG » Tue Oct 11, 2011 7:53 am
TIG Tue Oct 11, 2011 7:53 am
Right now Octane Power Tools supports 3D Max, Blender and LightWave and Maya. Other packages will be supported very soon!
Reading between the lines it seems to me you want to batch export SKP scene-cameras and sun settings to do something similar - using a turbo-version of my OCM Exporter?
TIG
TIG
Re: OCM EXPORTER
Postby Interfaces » Tue Oct 11, 2011 10:14 am
Interfaces Tue Oct 11, 2011 10:14 am
yes!!!,, exactly
Interfaces
Re: OCM EXPORTER
Postby TIG » Tue Oct 11, 2011 10:37 am
TIG Tue Oct 11, 2011 10:37 am
I have just written a new fast batch exporter for all cameras and and all suns...
See its new thread when I publish it shortly... :ugeek:
EDIT: Here viewtopic.php?f=31&t=8955&p=66100#p66100
TIG
TIG
Re: OCM EXPORTER
Postby gilfanovruslan » Tue Oct 11, 2011 10:37 am
gilfanovruslan Tue Oct 11, 2011 10:37 am
Tig, are you involved in viewtopic.php?f=7&t=8785 ? Hope...
Win 7 x64 |gtx560ti 2gb | 2600K | 16gb | Google translator
gilfanovruslan
Re: OCM EXPORTER
Postby TIG » Tue Oct 11, 2011 10:48 am
TIG Tue Oct 11, 2011 10:48 am
gilfanovruslan wrote:Tig, are you involved in viewtopic.php?f=7&t=8785 ? Hope...
Anyone who might be involved in it couldn't tell you, because they would almost certainly have entered into a 'Non-Disclosure Agreement'...
But you can be sure that there will be some interesting new developments over the coming weeks :ugeek:
TIG
TIG
Return to SketchUp
Mon Oct 26, 2020 10:26 pm [ UTC ]
