Hi, i'm using the latest Sketchup exporter and for some reason it does not start up with this skp file. All others work fine. Attached is the file any idea why only this file?
Patrick
Sketchup Pro 8, Win Pro 7, i7, EVGA 570 GTX, 16gb ram
Sketchup exporter not working on this file?
Patrick, Arch. Tech.
Fritsch Plans Workshop Inc.
http://www.FPWI.ca
SketchUp Pro 8, Win 7 Pro 64 Bit, i7 3.40Ghz, nVidia EVGA GTX 570 1280mb, 16384 mb RAM, Asus P8PP67
http://www.FPWI.ca
Had the same problem with a sketchup scene.
I opened a new sketchup file and imported the corrupt scene and the exporter started well again.
Kind regards
Alain
Kind regards
Alain
Intel Pentium 2.8 GHz 2 Cores, 8 GB RAM, GeForce GTX Titan 8GB, Blender 2.72b, Win 7 64 Bit
There was no SKP attached.
As Alain's reply says, it may well be that your SKP needs 'fixing' - see Model Info > Statistics > Fix Problems [Purge Unused is also sensible to reduce the database/file size too].
Also note that using special-characters/accents in the file-path to the SKP and Project will cause failures too...
If you can zip the SKP and attach it we can have a look...
TIG
Thanks Boys! There was an appostrophe in the file path name. File works fine now.
Patrick
Patrick
http://www.FPWI.ca
http://www.FPWI.ca
