leaf translucency - test thread
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
cornel
Hi friends,
some things I found out & like to share when wondering about translucency on single sided leaves.
-Instead of using a Diffuse + greenish RGB Spectrum for transmission, you can also create something similiar looking by creating a Specular material:
Set its reflectance to "0", its index (refraction) to "1" and increase its roughness value.
Now plug your leaf texture to the transmission port, done.
This also looks good when used in a 50/50 mix with your old diffuse material.
even better: Use Photoshop to create some additional textures: bump, transmission, opacity.
Will boost realism a lot, even on low-res leaf geometry.
All test renders were lit by a huge emitter with a strength of 23.000 and no extra environment light.
pathtracing.
Win 7 x64 | GTX770 Phantom 2GB | Phenom II X6 3.2GHz | 16GB
mlody47
great man!! Thats very very usefull.. I think Ill try the third material in the first pic. for the wax material :)
NICE! and Thank You.
i7 2600K + 2X gtx 580 + GTX 560 Ti + 8gbram + Win7 +
AUTODESK SOFTIMAGE 2012
www.behance.net/mlody47
radiant
If it is possible can you post the ocs, obj, mlt and the textures, if it is alright with you i can add this to the octane tutorial series ;)
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
radiance
this looks really nice, maybe you could post it in the resources forum too ?
Radiance
mbetke
Wow complex shader tree setup. Must take a lot of resources to compute. But the result is very good. WOuld like to see a render with a backlight sun on a tree.
PURE3D Visualisierungen
t_3
this looks very, very nice! thanks for sharing your ideas.
ps: i'm also keen about the rendertimes for the images you posted...
hmk
This is great, i will try it in my low poly trees. Thank you for sharing.
http://www.OctanePowerTools.com
Octane Render Power Tools, Animation Tools for Octane Render
facebook | YouTube
Intel Core i7 920 @ 2.67GHz - RAM 12.0 GB
Asus P6T7 WS SuperComputer GTX 480
cornel
Thanks guys.
@radiant: I´m sorry, I can´t provide the ocs & obj as this is the leaf is a commercial model from evermotion.
@t_3: rendertimes laid between 20 and 60 mins for a 2K resolution, pathtracing with a raydepth of 64.
Oh, could an admin move this thread to the resources forum?
mlody47
Hey , I can get You some tree model... which I could allow You to share ;)
mbetke
I will set it up with an Ivy model. Will check back later. Need to get myself a beer and start then. :)
Return to “Resources and Sharing”
