Noticed the same thing, only seems to happen with motion blur box checked.YoonKyung wrote:The 1st and 2nd, 3rd and 4th, and so on output images of Turn Table Animation are same.
OctaneRender® 1.0 beta2.52 >>> download here <<< [OBSOLETE]
After even further testing, it happens with only one 480 enabled aswellPeterCGS wrote:After further testing... This happens only when both my 480GTX cards... Running in single mode works perfectly, so its something that locks up Octane in Dual GPU mode.PeterCGS wrote:Octane doesnt seem to quit properly. Rendering animations in XSI previously has been working really well. But with 2.52 Octane randomly doesnt quit properly, and is idle in the task manager disabling to render a new frame, without going into the task manager and shut it down.
Win7, i7 980 Hexacore, 24GB RAM, 3xEVGA SC 670 GTX 4GB
Doesn't change a thing. I changed from 275.33 to 280.26 and it had no effect. My animation rendering is still stopping at random times. Today it stopped after 6 hours of rendering.PeterCGS wrote: After even further testing, it happens with only one 480 enabled aswellIt just took a little longer before it hangs.. I've tried with driver 275.33, but will now install 280.26 to see if it solves the problem.
Intel i5 2500k@4,5 Ghz | Asus P8Z86-V Pro | 16GB DDR3-Ram | Nvidia 580GTX GDDR 3GB | Win7x64 | Softimage 2011 SP1 x64 | Octane 2.52 x64
Thanks for this release, I can see some improvements in the stability for animation rendering since 2.46. (out of Blender).
I'm not saying it's perfect, there are still some freezes of the render process once in a while but it happens less often than before.
Keep up the good work guys !
Titan Black + GTX 580-3go / Win 7 pro 64 bits / C4DR14 with integrated plugin / Blender / Octane standalone /
website : http://www.kiwimage.com
Have only found one other person with this problem but in beta 2.52 Motion Blur doesn't seem to do anything in a turntable animation. Octane saves two identical images per frame neither with blur. Maybe its my settings but for now I rolled back to 2.46b, removed my portal windows and it seems to work fine. Any ideas if this is a bug or something about my scene??
I had the luck to see how octane "crashed" when rendering an animation.
Octane was loading the images, then importing the model, voxelizing, the message disappears and that's it. No active octane window! In the task manager process tab is an octane.exe running, takes about 1.5gb of ram (when the scene normally renders it takes about 2.3gb of ram) and no cpu. I also checked the gpu load with gpu-z but there's nothing 0% load.
I have to cancel the animation export in xsi and shutdown the process manually.
It's really annoying, it already costed a lot of time.
- teecee2107
Thanks, Roubal, I followed your advice (switched to Win 7 x64 and add 4Gb RAM, my mobo does only accept 8Gb). Whoaw, I'm not sure I'm still using the same program !!! No more 'loading' problems, I can use full size textures, interface is much more responsive ... que du bonheur.ROUBAL wrote: I think that you would need to switch to Win 7 x64 and add RAM up to 8GB or more if your motherboard allows more.
You are absolutely right, even if the video card is crucial (amount of vram and cuda cores wise), a decent amount of ram is also really important.
Core 2 Quad Q9400 | 8Gb | Zotac 580 GTX 3 Gb | Windows 7 64bits | Octane 1.11 | Nvidia Driver 310.70
