terrain render
zivko
i doubt i could make a realistic looking terrain without instances so i decided to try make it look like realistic scaled model.
any ideas how i could improve this?
desktop - win7 64bit, i5-4690, 12gb ddr3, 970gtx 4gb, 460gtx 2gb
laptop - win7 64bit, i7-2630qm, 10gb ddr3, 550m 2gb
mbetke
I think you should skip the normalmap. It makes it look not ver real. Use lots of more trees. I think 2D planes are good to go. Use small bitmaps. Maybe you could even use a scatter script for it.
Add some haze or fog later and take a look at aerial photos to get a feeling of the colors. The terrain image should be as high-res as possible.
PURE3D Visualisierungen
ROUBAL
Not bad imho,but on the third image, the bump or normal map of the road seems to be inverted...
zivko
thx for the tips, i added some distance fog and desaturated warm colors in the distance. i also scaled down trees and instead of low polygon models i decided to use planes with tree maps
i still have a lot of modeling to do on the ground plane (make roads, few industrial buildings and houses, power cables and towers and so on) and i'm having problems with bump map, i have to figgure out how to make normal map, i'm guessing that would be better for what i'm doing. if there are some tutorials on how to do that here on forum, i'd appreciate if someone could link them, i'm using rhino
zivko
added cloud shadows
radiance
looks very nice already, maybe make the water reflective with a mix material mixing your current one with a specular material and modulating with a texture map ?
Radiance
madcoo
That's great work imho.
However, I think your trees definitely need more work done to them.
Maybe modelling them in detail wouldn't do much, because they're so tiny...
=> Did you try replacing them with simple planes in your model, then using an image of a real tree, and apply the texture + alpha map onto the planes?
Anyway that's a very cool approach to 3D I think - never seen anything like this before ;)
Keep us informed with updated pics !
2011 New Year Competition - 2nd Prize winning image
Visit my website: Fairview Studio 3D - Facebook page
i7 Quad-Core 2.67Ghz / 16Gb RAM / Windows 7 64bits / 2x GTX 680 / Octane v2.0 / CUDA Driver 6.0
zivko
thx for the comments, guys
madcoo wrote:Maybe modelling them in detail wouldn't do much, because they're so tiny...
those are simple planes in the kast two pictures, but they're arrayed and overlap a bit so i realized later that i need to reduce opacity of a map to get them to look less dark.
it looks better in latest tests, but i'm not gonna post anymore pictures unless i have all models and textures finished (theres going to series of pictures showing terrain as it is now and how it will be modified to fit the needs of wattter pumps that are going to be built in the area and how it would look if underground watter levels are raised if a haydrodam is build a bit further down the river). i think i'll have models and textures done simetimes this weekend and if i have better renders i'll post again
madcoo
Cool ;)
Looking forward to the nex pics !!!
Return to “Works In Progress”
