Hi
I started an animation render last night and at some time during the render Octane crashed with the following message (see below) I am unable to re render the anim without receiving the same error. I had made a backup of all associated Octane files prior to rendering the animation (this is not the first occurance of this problem) and tried using those but with the same result. I can however render a still frame which I let render to the full sample rate I have set in the animation.
I believe the only solution left to me at the moment is to set up the render again (applying materials/ lighting etc) thus creating a new .ocs file. This would be time consuming as I have a large number of Octane materials and scene objects. This is one of a number of animation we have to create in the next couple of weeks and I need to find a solution quick.
Any help would be appreciated
Windows Vista SP1
Intel Core 2 Quad 2.40GHz
4 GB RAM
32-bit
GeForce 9800 GT
3DS Max 2011
Octane 1.0 beta 2.46
There was an error parsing the command-line arguments:
Couldn't find match for argument Argument: F:\vStrat\shared_assets_\Ocatane_Materials\for_render\shot42\\shot_28_001.ocs
USAGE:
dummy program name [-m <string>] [-r <filename>] [-l <filename>] [-n
<filename>] [--imager-exposure <float>]
[--daylight-sundir-z <float>] [--daylight-sundir-y
<float>] [--daylight-sundir-x <float>]
[--cam-lensshift-right <float>] [--cam-lensshift-up
<float>] [--cam-aperture <float>] [--cam-focaldepth
<float>] [--cam-fov <float>] [--cam-motion-up-z
<float>] [--cam-motion-up-y <float>]
[--cam-motion-up-x <float>] [--cam-motion-target-z
<float>] [--cam-motion-target-y <float>]
[--cam-motion-target-x <float>] [--cam-motion-pos-z
<float>] [--cam-motion-pos-y <float>]
[--cam-motion-pos-x <float>] [--cam-up-z <float>]
[--cam-up-y <float>] [--cam-up-x <float>]
[--cam-target-z <float>] [--cam-target-y <float>]
[--cam-target-x <float>] [--cam-pos-z <float>]
[--cam-pos-y <float>] [--cam-pos-x <float>] [-q] [-g
<int>] ... [-s <int>] [-o <filename>]
[--film-height <int>] [--film-width <int>] [-e] [--]
[--version] [-h] <filename>
Where:
-m <string>, --mesh-node <string>
Name of meshnode to render
-r <filename>, --relink-meshnode <filename>
Name of OBJ mesh file to relink rendered meshnoded with
-l <filename>, --link-meshnode <filename>
Name of OBJ mesh file to link after startup
-n <filename>, --new <filename>
Create a new OCS project file from given command line arguments
Imager Exposure Amount
Daylight Sun Direction Vector Z Component
--daylight-sundir-y <float>
Daylight Sun Direction Vector Y Component
Daylight Sun Direction Vector X Component
Lens Shift Right
--cam-lensshift-up <float>
Lens Shift Up
Camera Aperture Radius
--cam-focaldepth <float>
Camera Focal Depth
--cam-fov <float>
Camera FOV (degrees)
--cam-motion-up-z <float>
Camera Up Motion 2nd Vector Z Component
Camera Up Motion 2nd Vector Y Component
Camera Up Motion 2nd Vector X Component
--cam-motion-target-z <float>
Camera Target Motion 2nd Position Z Component
Camera Target Motion 2nd Position Y Component
Camera Target Motion 2nd Position X Component
--cam-motion-pos-z <float>
Camera Motion 2nd Position Z Component
Camera Motion 2nd Position Y Component
Camera Motion 2nd Position X Component
--cam-up-z <float>
Camera Up Vector Z Component
--cam-up-y <float>
Camera Up Vector Y Component
--cam-up-x <float>
Camera Up Vector X Component
Camera Target Position Z Component
Camera Target Position Y Component
Camera Target Position X Component
--cam-pos-z <float>
Camera Position Z Component
--cam-pos-y <float>
Camera Position Y Component
--cam-pos-x <float>
Camera Position X Component
-q, --quiet
Start Application without splash and minimized window
-g <int>, --gpu <int> (accepted multiple times)
add GPU device to use for rendering (0 = first)
-s <int>, --samples <int>
Maximum number of samples per pixel (maxsamples)
-o <filename>, --output-png <filename>
Output PNG imagefile when maxsamples is reached
--film-height <int>
Film height
--film-width <int>
Film width
-e, --exit
Close the application when rendering is done
--, --ignore_rest
Ignores the rest of the labeled arguments following this flag.
--version
Displays version information and exits.
-h, --help
Displays usage information and exits.
<filename>
.OCS Project scene file
Octane Render
Animation - Argument Crash
