UNOFFICIAL plugin for 3ds Max 2010+
JimStar
I think I found the reason. Fixed it in 1.15.:)
Jaberwocky
JimStar wrote:I think I found the reason. Fixed it in 1.15.:)
coool ... i'll give it a try. ;)
Jaberwocky
Jim
Yes It works perfectly now.
I uninstalled 1.14 and reset max back to default settings.Reset the max start Ui and rebooted max.
I then reloaded V1.15 and it installed perfectly including the 2 commands in the bottom of the render menu.
if no one else reports any problems you could probably ditch the 2 or 3 diagram screens on the front end of the plug in installer.
Cheers
Jabba
JimStar
Found small bug in plugin itself... Fixed in 1.16...
Jaberwocky
Not sure if I'm doing something wrong but pressing the render animation button does not start rendering an animation.
Jaberwocky
Tried re-running one of the stock max 2012 animation scenes and this then came up.It might be a clue
JimStar
Jaberwocky wrote:Not sure if I'm doing something wrong but pressing the render animation button does not start rendering an animation.
Does export process begin after pressing? Or nothing happens?
If export begins - can you check please what is in the "Renders/Animation" folder after pressing?
JimStar
I found some bug in animation processing, fixed it in 1.18. Maybe it will resolve issues...:)
Jaberwocky
The animation folder is empty.See the attached the project folder one level up.
Edit ----- OK will try V1.18------------
Jaberwocky
Ok
V1.18 seems to have fixed it.It's now rendering the animation in the background whilst i type this.
I'll report back when its finished.
Cheers
Jabba
Return to “Autodesk 3Ds Max”
