Mazda Rx-8 and Interior render
monkeyjet
I'm new to Octane, but man this is really cool software!
These are modeled in Softimage, rendered in Octane 2.47.
Any critiques are welcome!
Thank you!
Interior render
Interior render
Rx-8
Rx-8
infernoVFX
Hi monkeyjet,
The bodywork is just flawless, the only thing that needs a little bit more work are the tires and the disc brakes. I'm not judging the render quality because its just plane and simple, but from a modelling point of view you've done a good job.
All the best,
Voja
Asus rampage III extreme, i7 950 OC 4GHz, Kingston 12GB DDR3, WD VelociRaptor 300gb, 2x WD Black 640gb, Asus ENGTX 580//
Gigabyte P67A UD7 B3, i7 2600K OC 5GHz! Mushkin Blackline 16GB DDR3, OCZ vertex3 SSD, WD black 1TB, MSI GTX 580 lightning OC 993MHz!
FamilyGuy
White balance would be welcome.
BTW can someone tell me why all Octane Renders pictures are so green? I have a big problem with that. Only PS help me to figure out this.
monkeyjet
Thanks guys for inputs!
Wow that image looks much better!
All this time I didn't know how to adjust white balance properly, but now I found tutorial online.
It is great thing to know!
Thank you!!
abstrax
FamilyGuy wrote:White balance would be welcome.
There is two things you can do: Try fixing it in the lighting (for example the blackbody temperature) or with the camera response curve in the imager.
Cheers,
Marcus
