New Soft2Octane export test release [Obsolete]
Forums: New Soft2Octane export test release [Obsolete]
Re: New Soft2Octane export test release
Postby Magog » Fri Jul 15, 2011 7:26 am
Magog Fri Jul 15, 2011 7:26 am
I face! Congrat for your work!
This plug is very fast!
Finally the area light is now enable, but I have a little problem.
To me it is a strange thing happened. Once I have exported the file with a new plug on Octane, I can no longer export to other files in Octane, after making changes to XSI.
I mistaken something?
Besides, the uv generated with unfold don't see in Octane. :(
i7 970 3.3 GHz | 12Gb Ram | GTx550Ti for display + Gainward GTX580 1.5 Gb and Zotac 590 3 Gb for Octane | Win7 x64 __ Softimage 2011.5
Magog
Postby face » Fri Jul 15, 2011 7:50 am
face Fri Jul 15, 2011 7:50 am
Magog wrote:Once I have exported the file with a new plug on Octane, I can no longer export to other files in Octane, after making changes to XSI.
What do you mean with export to other files? You can´t change the project name?
Magog wrote:Besides, the uv generated with unfold don't see in Octane. :(
Maybe you have two uv-sets on the mesh? Because the obj can only have one uv-set, i take the first.
face
http://vimeo.com/user2509578
face
Postby Magog » Fri Jul 15, 2011 11:26 am
Magog Fri Jul 15, 2011 11:26 am
After the first export, I close Octane to return on XSi for other edit on various mesh, for example.
When I export to view the result on Octane, the plug don't export nothing.
In reality nothing happens..
The Unfold is the only uv set!
Magog
Postby face » Fri Jul 15, 2011 2:51 pm
face Fri Jul 15, 2011 2:51 pm
Magog wrote:After the first export, I close Octane to return on XSi for other edit on various mesh, for example.
It should, because i write in a tmp-file.
If the export is done, without a chancel, I delete the original obj-file and rename the tmp-file to the original one.
Maybe you can export a bigger mesh, like 150.000 tris and have a look in the project folder. There should be a projectname_tmp.obj.
Magog wrote:The Unfold is the only uv set!
Hm, curious, i havn´t changed anything in the uv export. I have test it with modo and the uv is exported and shows like the one in xsi.
Which Softimage you use?
I have compiled the plugin with 2010sp1, maybe that´s the problem...
face
face
Postby Magog » Fri Jul 15, 2011 4:10 pm
Magog Fri Jul 15, 2011 4:10 pm
I use SI 2011.5.
In the next day i tried other test..
Magog
Postby face » Sat Jul 16, 2011 12:03 pm
face Sat Jul 16, 2011 12:03 pm
I´m working on Strands, so that they are ready in the next release.
The scaling problem should then be fixed and they should look the same as in SI.
I have found, that the strandlength have influence.
The length is multiplicated with the size, so that different lengths of the strands give different sizes...
Have also found, that there is an issue with pointclouds if they haven´t a point position or an instance shape.
The export then was canceled. This is also solved...
face
face
Postby jamnique » Sat Jul 16, 2011 2:05 pm
jamnique Sat Jul 16, 2011 2:05 pm
face wrote:I´m working on Strands, so that they are ready in the next release.
face
Great! This is the best version i have used so far. Can't really prove it but it seems faster and it's the most stable one. Not that the previous ones were particularly glitchy. I couldn't find any bugs so far. Thanks.
Intel Core2Quad 9200 / 4 GB OCZ / Gainward 460 2GB
jamnique
Postby face » Mon Jul 18, 2011 12:02 am
face Mon Jul 18, 2011 12:02 am
Quick strand comparison between Softimage and Octane...
They should be match ;)
I think the Softimage normals aren´t correct...
face
Softimage
Octane
face
Postby jamnique » Mon Jul 18, 2011 7:15 am
jamnique Mon Jul 18, 2011 7:15 am
Great, strands are what i need right now. Thanks!
jamnique
Postby face » Mon Jul 18, 2011 8:14 am
face Mon Jul 18, 2011 8:14 am
Next try.
Only cubes with a lattice deform.
Around 1.6mio triangles...
face
face
PreviousNext
Wed Jun 05, 2024 4:48 pm [ UTC ]
