Hi all,
Any way of using octane in a computer through remote desktop?
it says 'no cuda devices found'
thanks
Remote Desktop and Octane
Can't really confirm that, but i know for sure that TeamViewer works fine for that purpose. You can use it for free as long as you are doing your personal work.areyal wrote:Hi all,
thanks
Intel Core2Quad 9200 / 4 GB OCZ / Gainward 460 2GB
imho all programs started within a win rdp session only see the terminal services vga driver, which gets effective while such a connection is active; thus they have no chance to access any real graphics hardware. the solution is to use vnc or something like that. e.g. ultravnc (free) has quite ok screen performance, and allows an even headless octane station...
„The obvious is that which is never seen until someone expresses it simply ‟
...on thing to pay attention, if you want to run a headless machine (i.e. no monitor attached), are nvidia driver settings. because the driver decreases gpu clock to minimum after a while, if no monitor is attached - even if octane produces 100% usage. so you need to force a constant clock frequency like this: http://forums.nvidia.com/index.php?showtopic=192720
Ahmm.. that's important, thank you t_3
the card I use by now has no monitor and I didn't experiment downclocking. I suppose then It only happens with computers with no monitor at all, even on other cards
GPU GTX 480 / GT 430 for UI
CPU Intel Core 2 Quad Q8300 (2.5 Ghz) / RAM 8 GB DDR2
SOFT Windows 7 64bit4
hm, as this is apparently handled on driver level, it could work like that. i have headless machines running (with no monitor attached at all) and did experience this downclocking. it could also be dependent on driver version (nvida does often creatively change things), or other things...areyal wrote:Ahmm.. that's important, thank you t_3
