Stupid issue i don't know how to solve
Ayertosco
Well...every time i start Octane, it automatically load my last work scene. Since today it wasn't a problem even if it was strange because i was only working on that project. But today, trying to export an animation from Cinema 4d, as Octane starts, it keeps loading that scene, loading textures and mesh and so on. Even if i "cancel" the loading, i don't load the animation mesh and that's disappointing. So, probably it's simple to solve it, even if i tried to remove octane, clean the registry and other things but i think that there's some configuration file that stores octane configuration and information somewhere and maybe the issue it's in there.
Thanks.
AMD Phenom X4 965 B.E. / ATI 5850 1GB / Nvidia GTX 580 1.5GB/ 8GB ram / Win 7 x64
Jaberwocky
Ayertosco
Try this location
delete the Defaults file and restart octane.
It reverts to a Vanilla state.
Ayertosco
Jaberwocky wrote:Ayertosco
Try this location
it worked! Thanks a lot, couldn't find that little bastard :D
EDIT: Ok, it worked as i start Octane from the Programs menu, but if i launch a Render animation from cinema 4d, it keep loading this scene. Moving the OBJ and the scene doesn't solve it cause it ask me to locate the project mesh. That's annoying.
abstrax
Ayertosco wrote: it worked! Thanks a lot, couldn't find that little bastard :D
Is the defaults.ocs file gone or was it recreated? What does the scene file contain, which you try to render as animation? Does that scene file actually get opened, when you render the animation?
Cheers,
Marcus
Ayertosco
Now it's solved, i forgot to edit again. The Default.ocs wasn't recreated but now it open the right scene for animation.
