OctaneRender® 1.024 beta 2.48 TEST (win) [OBSOLETE]
Material ball pop-up is the biggest problem here too, i pick a material from the viewport, change its type (i.e. diffuse, specular, glossy, material mix) the material ball scene automatically comes to view. it doesn't pop up only when i select "portal" (which works fine by the way)
my biggest annoyance is when ever i change a material from diffuse to any other, it goes to the material preview on the ball. I dont want this, i want to edit my material to my scenes lighting and illumination set up. And for the past releases whenever i do change the material, ALL materials un collapse, then i have to minimize all of them it is EXTREMELY annoying.
Other then that im getting a a 5 minutes reduction on my renders with multigpu
. It makes a big difference when you add another 512 to 512 cores.
And can someone please explain to me how portals work?
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
- Jaberwocky
Radiant
Try this link for an explanation on Sky light Portals. I know is for 3D Max but you should get the idea from it.
http://download.autodesk.com/us/3dsmax/ ... r=d0e28455
sorry i've wrecked the bug report list with this ..I 'll try and keep to bug reports from here on in.
Jabba
Jabba
- SamCameron
I tried the portal material without luck, I have no idea how to make it work, apart of this... the multi gpu is working AMAZING, twice the speed I had before, no I just wish I have something like this officially supported:
And then I could consider Octane Render really as a render engine killer.
I just discover that 2.48 has been released. I am not on my workstation and I can't test it right now, but I have to say thatYou mean the material ball preview scene? It doesn't "pop up" here, when I make a change in the node inspector. What kind of changes do you make?
- Elvissuperstar007
- Contact:
SamCameron wrote:I tried the portal material without luck, I have no idea how to make it work, apart of this... the multi gpu is working AMAZING, twice the speed I had before, no I just wish I have something like this officially supported:
http://octanepowertools.com/
octane costs 99 euros! If each script will cost 60 euros, it somehow did not understand!
price is not adequate for the plugin
- ribrahomedesign
Hi there.
Just tested the new release with my new GTX 590 and I dont know ,but multy GPU
worked for me better with the preview release , even if the multy GPU not worked
properly with release 2.47. I know the sample counter has been updated ,but regardles
I think 2,48 is slower then 2,47. you shouldn't have changed anything about the Fps ore Ms/sec.
because now we cant compare with 2.47
regards
Rico
regards
Rico
Windows 7 , 64 b / GTX 590 / Archicad 15 , 64 b / Cinema 4D R 13 studio , 64b /Intel(R)Core(TM)Extreme3,20Ghz /always latest Octane.
This looks mighty fine. Too bad its price is almost half the Octane beta's. I wonder if something like this will be developed by Refractive or exporter developers.SamCameron wrote:I tried the portal material without luck, I have no idea how to make it work, apart of this... the multi gpu is working AMAZING, twice the speed I had before, no I just wish I have something like this officially supported:
Intel Core2Quad 9200 / 4 GB OCZ / Gainward 460 2GB
PMC is double time slower then PT
PMC seams to become very heavy comparing to ver.before
PT literaly eat all graph.card memory i never seen mes.like on pic
Older octane file didnt work on this ver. i had problem with camera. File was loaded but i was not able to move with mouse, only with keyboard input, numeric input in cam.setings
PMC and PT are somehow slow...i have feeling that i downgrade my card a little bit
but that is probably cos i expected optimization of rendering engines
counter, including time of rendering is working, but bumpy...it works in waves...like my comp is choking
min_display_samples what is this ?
keep on good work
keep on good work
ArchiCad, Blender, Moi3d
GTX 580 3GB
Win 7, 64 Bit
GTX 580 3GB
Win 7, 64 Bit
- ribrahomedesign
tested Portal.???
don't really see the point . shouldn't portal light speed up the rendering,IMO yes.
but here it is slower then specular ??.I am normally not the person who complains
but i don't really see the point of this release .am I the only one ?
Rico
Rico
