OctaneRender® 1.024 beta 2.47 (lin/mac/win) [OBSOLETE]
- Elvissuperstar007
- Contact:
shader falloff needed
Hey guys, I know the first post is 24 pages away, but this is a thread about the PMC kernel and not about wishes, requests and ideas. I really would like you to stay on-topic. We all know that there are a lot of things that can/should be added and we will do our best to make Octane more complete, but please discuss that somewhere else. Also be aware that there is only so much we can do at a time and talking about feature X or Y a lot doesn't develop it faster. (Although I wish it would be like that
I hope that makes sense. Cheers,
Marcus
Marcus
We will see...abstrax wrote:Hi Face,face wrote:Same problem with exit on 1024_beta2.43
Maybe i should try an other wdm as gnome 2/3...
face
It's possible that the coming test release might solve the problem. -> I wouldn't spend too much time on it until it is released. As I don't know what is causing your problem it is very well possible, that the problem is there, too.
Cheers,
Marcus
I have test it on icewm, blackbox, fluxbox, gnome2, gnome3 and kde, with my gtx285 and gt210.
Since beta 2.44 I can´t exit.
Ok, i will wait for the next release and stop the current development of the linux Soft2Octane plugin...
face
http://vimeo.com/user2509578
- Elvissuperstar007
- Contact:
Thank you!abstrax wrote:Hey guys, I know the first post is 24 pages away, but this is a thread about the PMC kernel and not about wishes, requests and ideas. I really would like you to stay on-topic. We all know that there are a lot of things that can/should be added and we will do our best to make Octane more complete, but please discuss that somewhere else. Also be aware that there is only so much we can do at a time and talking about feature X or Y a lot doesn't develop it faster. (Although I wish it would be like that)
Marcus
Hi Face,face wrote:We will see...abstrax wrote:Hi Face,face wrote:Same problem with exit on 1024_beta2.43
face
Cheers,
Marcus
face
are you saying that in beta 2.43 Octane closes correctly, but in beta 2.44 (or later releases) it doesn't? Which build do you use CUDA 3.0 or CUDA 3.2? Are you using it in multi-GPU mode?
Cheers,
Marcus
I meant glossiness of translucency (of the light that gets through). That should solve problem with curtains mentioned before enabling more than 50% of light to pass through.MaTtY631990 wrote:You can add glossiness in octane
http://www.visnevskis.com
Vista64/Ubuntu, GTX470/580
now thats a music for my earsradiance wrote:Hi all,
After our next 2.5 build is out (soon), with the rewritten multi-gpu framework),
we will start work on the final major feature being the new IO file format and instancing support.
Radiance
Intel Core i7 980x @ 3,78GHz - Gigabyte X58A UD7 rev 1.0 - 24GB DDR3 RAM - Gainward GTX590 3GB @ 700/1400/3900 Mhz- 2x Intel X25-M G2 80GB SSD - WD Caviar Black 2TB - WD Caviar Green 2TB - Fractal Design Define R2 - Win7 64bit - Octane 2.57
Hi Marcus,abstrax wrote: Hi Face,
Cheers,
Marcus
2.43 with CUDA 3.0 & CUDA 3.2 in singel-GPU mode doesn´t exit.
If you need it, you can have a look via remoute desktop or how it names...
face
Hi there,
I was testing to recreate some TV studios with new PMC kernel.
I'm having issues getting rit of fireflies with my PMC kernel:
Too bad my HD with source file crashed a few minutes ago, was only able to save 1 test export png.
With daylight i have hardly any fireflies (although not what i need in interior scene) , but with the emitters like this one can't get rid of it, what i'm i doing wrong?
Win 10 64 bit + Linux Ubuntu | Nvidia RTX 2080TI | AMD Ryzen Thredripper CPU 2970WX 24-Cores/48-Threads | Houdini - Cinema 4D - Maya - 3Dsmax
There are no "fireflies" in that image, maybe 2 bright pixels. If you mean the cyan areas: Those occur in areas that are too bright. The next test release will work around this problem like in path tracing and direct lighting. Until then try to decrease the brightness of the emitters and increase the exposure in the imager/tonemap node.TheOracle wrote:Hi there,
Cheers,
Marcus
