OctaneRender® 1.024 beta 2.47 (lin/mac/win) [OBSOLETE]
Elvissuperstar007
COLLADA!!! is very necessary! how can we export a scene for animation with multiple-million polygons?
TheOracle
collada would be a nice feature indeed.
Win 10 64 bit + Linux Ubuntu | Nvidia RTX 2080TI | AMD Ryzen Thredripper CPU 2970WX 24-Cores/48-Threads | Houdini - Cinema 4D - Maya - 3Dsmax
Elvissuperstar007
TheOracle wrote:collada would be a nice feature indeed.
octane at most miserable exporter!
and most especially for the most 3dsmaх
sorry for bad english!
MaTtY631990
kivig wrote:
MaTtY631990 wrote:create a a diffuse material linking to you curtain/cloth and link a RGB spectrum node to the transmission input of that material.
Does the trick! Hope there will be a glossiness parameter for transmission some day, but that's another thread again :)
You can add glossiness in octane. You can use a mix material and have a diffuse translucent material in one slot and a glossy material in another and just blend between them just a little and not to much. Will make do until the team advances on adding more material properties. :)
have a play with it and have some fun.
radiance
Hi all,
After our next 2.5 build is out (soon), with the rewritten multi-gpu framework),
we will start work on the final major feature being the new IO file format and instancing support.
Radiance
kubo
the next release is almost here and you already got us anxious to see the next next one, :lol: is going to be a fun summer with octane!
matej
All that sounds very nice, but I'm mostly interested in the features from this thread. What is the plan regarding that new functionality for nodes?
cgmo.net
face
Have switched to Fedora Core 15, but the problem is the same that i can´t exit Octane without the use of the kill command.
Also the PMC-problem is the same as in Fedora Core 14...
face
http://vimeo.com/user2509578
face
Same problem with exit on 1024_beta2.43 ;)
Maybe i should try an other wdm as gnome 2/3...
face
abstrax
face wrote:Same problem with exit on 1024_beta2.43 ;)
face
Hi Face,
It's possible that the coming test release might solve the problem. -> I wouldn't spend too much time on it until it is released. As I don't know what is causing your problem it is very well possible, that the problem is there, too.
Cheers,
Marcus
