OctaneRender® 1.024 beta 2.47 (lin/mac/win) [OBSOLETE]
necko77
adiarc wrote:
abstrax wrote:
necko77 wrote:can some1 tell me, do i have to adjust glass transparney to let say 0.5 to get sun in interior
if i leave glass transparency to 1 i dont get sun in interior
coefficient of dispersion is set to 0.012
what is correct glass parametars now ?
Don't use dispersion for windows. Only use dispersion if you need to, because it introduces spectral noise which takes longer to clear.
Regarding sun through glass: I haven't tested it, but I don't think you can get sun light through specular materials. You still have to use the architectural glass trick. Maybe Roeland can correct me, if I'm wrong here.
Cheers,
Marcus
What is the architectural glass trick? :?
http://www.refractivesoftware.com/forum ... ural+glass
chekc out this video and next time just type in search : architectural glass and you will find it !
ArchiCad, Blender, Moi3d
GTX 580 3GB
Win 7, 64 Bit
adiarc
Thanks a lot, necko77!
8Eggar8
I've never had luck with updating any NVIDIA drivers. Anytime I've ever had to change out from the default (sent stock) manufacturer's version sent with the card, I always experience system freezing results. It seems now I have Random system seizures whenever I have a browser open for a while (could very well be conflicting with a web based flash activation, seems to be because anytime I go to youtube for some background tunes the system locks up after a minute or two) but, in order to have CUDA 4 I 'must' have the newest graphics driver for my card, right? There is no other way to have the newer CUDA version without updating the entire card's driver?
Hell, even Window's crash reporter knows what's up, after re-booting after a lock-up.
Thank you for any answers you may have
MSI NF980-G65 AM3 NVIDIA nForce 980a AMD Motherboard - AMD Athlon II X4 620 (Overclocked to 3.2ghz)
(2)GTX460's, (1)BFG gtx260, OCZ 60GB SSD, KINGWIN 1000W Power, HAF 932 Full Tower, XP64
Octane V1 - 2.46 - CUDA 4.11 - OBJ's from Rhino4
Refracty
There is only problem with the 2.47 PMC release and multiple camera nodes.
On my system I can not switch between different camera nodes.
Did anybody else experience the same problem?
I hope RS will fix this soon because it is the major reason I can't use it for production.
Cheers
Refracty
abstrax
Refracty wrote:There is only problem with the 2.47 PMC release and multiple camera nodes.
Cheers
Refracty
It's already fixed :)
We probably won't make it this week, but we plan to release a new test version next week. It will include the new render framework with the new multi-GPU code and a few other goodies. It will then also be possible to use an ATI card for display and NVIDIA cards for rendering.
Cheers,
Marcus
matej
abstrax wrote: It will then also be possible to use an ATI card for display and NVIDIA cards for rendering.
For real?! :o
Without messing with drivers or requiring multiple monitors?
cgmo.net
Jaberwocky
coooool..
next week a new toy to have a play with. :D
FamilyGuy
abstrax wrote:It's already fixed :)
Cheers,
Marcus
And what about Intel GPU like HD 2000 and HD 3000 in Sandy Bridge procesors?
abstrax
matej wrote:For real?! :o
Yup. We don't have ATI cards at work, but a partner of us has tested it and said it works. And I don't see a reason why it shouldn't. The graphics driver of the display card must support OpenGL 2.1 or higher, but that should be no issue these days.
To FamilyGuy: For display these GPUs should work, too (as long as they support OpenGL 2.1 or higher). How good/bad I don't know, but we will learn it from you guys anyway ;)
Cheers,
Marcus
Elvissuperstar007
I hope it will SSS
