Hi all,
Here's a little test render with the new pmc kernel in 2.47+,
using dispersion on the glass bolts. (scene is by dave62, it's in our new testsuite)
It's raw output from octane, no post-proc.
The cauchy B parameter for dispersion is too high though, 0.1, it's not something any realistic materials would have, I just wanted to see as much dispersion as possible.
Radiance
							PMC dispersion bolts test
That looks great man.
What sort of render times should we expect once you've optimised it? Will it be faster than path tracing?
that looks really clean.
						I left it running overnight, and in the morning it was finished at 16000/16000.
I don't know when it was done though, and forgot to check... (should have taken a screenshot too... )
It looked pretty clean after on hour though, i'm sure 2 hours would have been more than enough, and I used one GTX460 GPU.
We're still working on optimizing the PMC kernel, at this time it's difficult to predict, but I'm hoping we can get 2x speedup after the optimizations are finished,
in a few weeks with the big beta 2.5 release.
Bidirectional pathtracing (and PMC) should make renders like this one converge MUCH faster,
and bidirectional pathtracing + PMC is something we will be starting work on next, after 2.5 is out.
PMC + bidirectional will be ideal, it will be as efficient as the popular standard in CPU based unbiased engines (MLT+bidir),
and this combines with the power of GPUs should really take things to a new level.
Radiance
 )It looked pretty clean after on hour though, i'm sure 2 hours would have been more than enough, and I used one GTX460 GPU.
Radiance
						- Jaberwocky
radiance wrote:I left it running overnight, and in the morning it was finished at 16000/16000.
I don't know when it was done though, and forgot to check... (should have taken a screenshot too...)
Radiance
That sounds great.......More speed.......I love speed........
Careful radiance...don't feed the zombies.
CPU:-AMD 1055T 6 core, Motherboard:-Gigabyte 990FXA-UD3 AM3+, Gigabyte GTX 460-1GB, RAM:-8GB  Kingston hyper X Genesis DDR3 1600Mhz D/Ch, Hard Disk:-500GB samsung F3 , OS:-Win7 64bit
						So is bidirectional path tracing like an add on or a modified version of path tracing?radiance wrote: Bidirectional pathtracing (and PMC) should make renders like this one converge MUCH faster,
Radiance
What is the difference between the two?
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
						It's a more complex algorithm, it's also unbiased, produces the same result (if implemented properly),radiant wrote:So is bidirectional path tracing like an add on or a modified version of path tracing?radiance wrote: Bidirectional pathtracing (and PMC) should make renders like this one converge MUCH faster,
Radiance
but is more efficient for caustics and hidden lightsources, as it traces rays from lights and from the camera,
and interconnects them.
It's quite complex to implement, and requires a complete foundation, which we now have.
It can also be combined with PMC to make it even better.
Radiance
						That sounds so good!
							Q6600 || 4GB || 9800GT || 512MB || Vista Home || C4D 9.6 & Blender
