Is anything can solve the problem of opacity?
Try switching over to the pathtracing kernel instead of the direct lighting kernel... Path tracing supports alpha shadows properly, however, it takes a much longer time to render.
Convergen | Adelaide Australia
Windows 7 x64 | GTX 580 1.5GB | 12GB DDR3 | Core i7 920 @ 3.6ghz
[quote="convergen"]Try switching over to the pathtracing kernel instead of the direct lighting kernel... Path tracing supports alpha shadows properly, however, it takes a much longer time to render.[/quote]
3q,but pathtracing is not work,too.
my oct version is 1.022 demo,is that can be affect the result?
Beta 1.22 is 7 months old and back then alpha shadows did not work yet,
The current versions, and the 1.46b demo which you can download on the downloads page does.
Neither of those 2 demo versions support the resolution your image is rendered in though.
So I guess you're not using a 'demo' version.
Radiance
Radiance
[quote="radiance"]Hi,
Beta 1.22 is 7 months old and back then alpha shadows did not work yet,The current versions, and the 1.46b demo which you can download on the downloads page does.....
Radiance[/quote]
Ya,i was use the new version at first time,but it tooks a bit more system memory ram(like the picture),so... :|
I don`t know what happened(maybe gtx260 or winXP 64bit isn`t good for the new version? :shock: )
Radiance[/quote]
- FH#%^&#^&@%q3tq3t.jpg (9.65 KiB) Viewed 3957 times
