Hi!
I need some help...
I can not scale an image on a material mix.
I'm making a shirt and want to put a stamp on top of a cloth texture. I Need to know how to make provision in relation to the axis X and Y on my shirt. the only thing I'm able to modify is the scale, but the stamp is not where I want.
I hope you can help me. Thanks.
Material Mix Help.
- Jaberwocky
I would suggest u.v. mapping the shirt in your 3D app.Then making the stamp map in something like Photoshop with an Alpha channel.Position it in your 3D app and then export to octane.Use the Mix material with the map to create the final map.Alternatively just do a UV unwrap of the mesh in your 3D app and then make a complete Map of the whole shirt and apply it in your 3D app.On export it should lay up on your shirt in the correct position.
