I really miss her
Feature request: Auto Smooth
luchschen
It would be nice to see in the next version of the function of such "Auto Smooth" in Blender.
I really miss her
I really miss her
Can you explain it a little bit more for non-blender users ?
http://Kuto.ch - Samuel Zeller - Freelance 3D Generalist and Graphic designer from Switzerland
luchschen
"Angles on the model that are sharper than the angle specified in the Degr NumBut will not be smoothed. Higher values will produce more smoothed faces, while the lowest setting will look identical to a mesh that has been set completely solid."
With my English, I can not explain.....
easier to read at this link
http://www.blender.org/documentation/htmlI/x2681.html
So you say that you want a slider inside Octane to define the smooth level ?
Like if the slider is at 0 = 0° angle smooth and slider at 45 = 45° angle smooth ?
So basically something like smoothing groups ala 3DSMax? Have you tried importing a mesh that has some auto smoothing into Octane(using .OBJ)? Does Collada/FBX support smoothing groups? If they do we could just setup the smoothing groups in our DCC apps instead of adding this feature into Octane.luchschen wrote:"Angles on the model that are sharper than the angle specified in the Degr NumBut will not be smoothed. Higher values will produce more smoothed faces, while the lowest setting will look identical to a mesh that has been set completely solid."
edit: you can get hard surface and smooth surface just by turning the "smooth" option on/off per material in Octane?
Maybe a smooth node that you can insert between the material and the mesh node could do that ?
That would allow smoothing-per-material
Or a global slider, or exporting correct smooth objects
Hey,
I do see us adding options to control these, but it's currently mainly a modeling issue that you can deal with in your 3d modeling app.
It would be handy to have it in octane yes, and i'll definately put it on the wishlist,
but i'm afraid this will take a while to be added as there are quite a bit of other priorities that we need to focus on now,
and users can apply smoothing in the 3d modeling app.
octane does import smoothgroups from OBJ files,
although it does'nt import them per smoothgroup (octane does'nt have a concept of smoothgroups currently),
but it handles them per material.
Radiance
Radiance
luchschen
I tried to export the objects with Auto Smooth. But it does not work in Octane.
Here's a picture of Blender c using Auto Smooth, without assigning smoothing groups
