hi
i rendered an image two times with the same amount of samples and it looks exactly the same -> also the noise..
is it planed to build in a feature like random seed in fryrender?
then you could merge different rendering to one image to reduce the noise... or in an animation with random "noise" you could use a temporal-filter like neatvideo to reduce the noise.
OR
is it possible to resume a image?
sorry for my english
feature "random seed"
Im not sure but I think that the noise is the same without MLT
MLT is currently being implemented
http://Kuto.ch - Samuel Zeller - Freelance 3D Generalist and Graphic designer from Switzerland
Sorry for the long delay in replying but i've been a bit sick during the last days.
I can add a seed option, it's indeed handy for making sure noise is different when combining renders, i've put it on my todo list.
Radiance
Radiance
Never heard of this approach (combining 2 noisy renders), any examples kicking around?
I like the fact that the noise is consistent, this bodes well for animation
Win 7 Pro (x64) | Geforce 295GTX | Quad 2.4GHz | 4GB PC-6400
Doesn't MLT introduce random samples by default ?
For my first images rendered with Octane for the competition (v0.7) I had a lot of fireflies, and I used this method : I added the second render on a layer in Photoshop with 50% transparency, and I even did sometimes 3 renders, with the third at 25%. It requires much more rendering time, but works fine and also remove grain everywhere (not only removing fireflies) like a longer render.Never heard of this approach (combining 2 noisy renders), any examples kicking around?
After that, with 0.8, the image had very few hotpixels, so I only removed them by hand with the one pixel clone pencil.
hi
thx radiance
for the other people
i think the most unbiased renderer has this feature for the following points (e.g. fryrender,maxwell,.. luxrender?)
- you can render the same image on 2 or more pc and merge the images to a less noisy image -> like renderfarm
- you can render an image and resume it on next day (also possible without random seed?)
- you can use a temporal-filter for animations -> love that but dont work on static noise
i am not a expert but radiance know what i mean
thx radiance
Win7 64 | Geforce 470GTX 1280MB | Q9550 2.83GHz | 8GB Ram | NVidia 306.23 , Cuda 5.0.1
