OctaneRender® 1.0 beta2.46b [OBSOLETE]
Jaberwocky
Not sure if this is a bug or just not implemented yet or has not yet been noted by anyone.
If you put say 3 camera's in a scene and set each camera up for a different viewpoint , f.o.v. and aperture setting then only the viewpoint on each camera is saved within that camera node.
the F.O.V. and aperture are not.
surely all the camera settings you make within each camera node that you create should be saved within that node.
stiwi
From the announcement of 2.46 I see, that there was a new manual included. Since I missed 2.46 (you guys are too fast for me), I haven´t got it. Is there a chance to load it somewhere? It´s not included in 2.46b. Thanks a lot.
stiwi
AMD Phenom II X6 1090T, 3.2 GHz
Zotac GeForce GTX 1060 AMP! 6 GB
Rhino 5
octane 1.20
WIN 7 (64)
abstrax
stiwi wrote:From the announcement of 2.46 I see, that there was a new manual included. Since I missed 2.46 (you guys are too fast for me), I haven´t got it. Is there a chance to load it somewhere? It´s not included in 2.46b. Thanks a lot.
stiwi
I just checked the installer and the manual is included. You will find it either in the application directory or in the start menu. There is also a download link of the manual in the download section of refractivesoftware.com (see above).
Cheers,
Marcus
GeoPappas
stiwi
I can confirm that the manual comes with the latest version (2.46b).
Godstrike
Just installed the commercial version of Octane - 1.0 beta2.46b (OctaneRender_COM_1024_beta246b_win_x64_cuda32.exe) - and it feels as if the UI responsiveness is inferior to that of Demo build 1.022 x64.
Anyone else noticed this?
Ryzen 5800x at 4.4GHz | 32GB | 1 x 3090 ti | 1 x RTX 2080 ti
mib2berlin
As wrote before i have still chrashes on closing octane or loading, save images.
Releasing cuda context on thread -456657152
Activating cuda context on thread -726235392
[Thread 0x7fffe4c7f700 (LWP 7871) exited]
[Thread 0x7fffd4b68700 (LWP 7870) exited]
[New Thread 0x7fffd4b68700 (LWP 7872)]
[Thread 0x7fffd4b68700 (LWP 7872) exited]
[New Thread 0x7fffd4b68700 (LWP 7873)]
[Thread 0x7fffd4b68700 (LWP 7873) exited]
[New Thread 0x7fffd4b68700 (LWP 7874)]
[Thread 0x7fffd4b68700 (LWP 7874) exited]
[New Thread 0x7fffd4b68700 (LWP 7875)]
[Thread 0x7fffd4b68700 (LWP 7875) exited]
[New Thread 0x7fffd4b68700 (LWP 7876)]
[Thread 0x7fffd4b68700 (LWP 7876) exited]
[New Thread 0x7fffd4b68700 (LWP 7877)]
[New Thread 0x7fffe4c7f700 (LWP 7878)]
[New Thread 0x7fffddde5700 (LWP 7879)]
Activating cuda context on thread -572631296
[New Thread 0x7fffd434e700 (LWP 7995)]
[Thread 0x7fffd434e700 (LWP 7995) exited]
[New Thread 0x7fffd434e700 (LWP 7996)]
[Thread 0x7fffd434e700 (LWP 7996) exited]
[New Thread 0x7fffd434e700 (LWP 7997)]
[Thread 0x7fffd434e700 (LWP 7997) exited]
Program received signal SIGSEGV, Segmentation fault.
(gdb)
Mayben this help to find out what happend.
Another linux user report also problems with closing octane.
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
thwak
Not sure that this is a 2.46 thing or not, but the 'Blender' preset in the Viewport Control Mappings section of the Preferences still does not work. You have to leave it set at the Octane preset and manually change all the individual settings.
Ubuntu 9.10 x64 | GTS 240 | 260.19.44 drivers | 3.0 Toolkit | Dual-Core 2.4 GHz | 4Gb| Blender 2.56a/latest Yoyoz plugin
WinXP32 | GTS 240 | 266.58 drivers | 3.0 Toolkit | Dual-Core 2.4 GHz | 4Gb | Blender 2.56a/latest Yoyoz plugin
stiwi
Cheers,
Marcus
Found it! Thanks!
Rhino 5
octane 1.20
WIN 7 (64)
Magog
with the 2.46b version I've a strange problem.. on the resolution size!
If I change the setting of resolution the vieport turns black and does exist solution.. I've to force quit Octane.
In addiction, the size 1200 x 700 is incorrect in vieport..
The file on which I'm working on is very large, it may be a problem of vram?
i7 970 3.3 GHz | 12Gb Ram | GTx550Ti for display + Gainward GTX580 1.5 Gb and Zotac 590 3 Gb for Octane | Win7 x64 __ Softimage 2011.5
matej
Magog wrote: If I change the setting of resolution the vieport turns black and does exist solution.. I've to force quit Octane.
Most sure. You'll have to save some of your ram and then change the resolution
cgmo.net
Return to “Commercial Product News & Releases (Download here)”
