OctaneRender® 1.0 beta2.46 [OBSOLETE]
Proupin
(about previous post) You need to see the mat list at all times??? I think a contextual menu could just pop up when you drop a node connection into another node, letting you choose the channel, material slot or whatever.
Win 7 64bits / Intel i5 750 @ 2.67Ghz / Geforce GTX 470 / 8GB Ram / 3DS Max 2012 64bits
http://proupinworks.blogspot.com/
PhilBo
[quote="Proupin"](about previous post) You need to see the mat list at all times??? I think a contextual menu could just pop up when you drop a node connection into another node, letting you choose the channel, material slot or whatever.[/quote]
Yes. It would be cool if it was a list box (or equal) where more than one can be selected. Imagine making a great new material and cntrl dragging (just my suggestion) the node to the object and being able to select a huge number of objects at one time and have them all be hooked up.
abstrax
The Mac build is up.
abstrax
The ZIP archives, too.
GeoPappas
abstrax wrote:The ZIP archives, too.
Thanks a lot.
My initial tests seem to show that the memory leak (when using alpha) is still there. It would be highly appreciated if you could squash this bug in the next release. I use alpha all the time and Octane eats up memory pretty quickly with this bug.
abstrax
GeoPappas wrote: My initial tests seem to show that the memory leak (when using alpha) is still there. It would be highly appreciated if you could squash this bug in the next release. I use alpha all the time and Octane eats up memory pretty quickly with this bug.
Yes, the problem is still there. I thought I had fixed this problem a while ago, but somehow it sneaked through the net...
Tomorrow we will release a beta 2.46b, which fixes a few regressions of beta 2.46 plus the memory leak (as far as we can fix it). It will be in the commercial release forum and the demo version will be based on that version, too.
Cheers,
Marcus
GeoPappas
abstrax wrote: Tomorrow we will release a beta 2.46b, which fixes a few regressions of beta 2.46 plus the memory leak (as far as we can fix it). It will be in the commercial release forum and the demo version will be based on that version, too.
Excellent...
ttaberna
This release is SWEEEET!!! :o
I've noticed that the sun power doesn't challenge my invisible lights powers...
And north offset works like a charm!
Thanx
Rampage IV Extreme+i7 3920k+2x GTX580 3GB+2x GTX470
Henrik
ttaberna wrote:This release is SWEEEET!!! :o
Thanx
certainly do not know about north offset yet,but why is it 100 minnutes in an Octane hour?
thanks for 2.46 Octane Team :D
Asus p67|Windows 10|GTX970_GTX1070|i7-2600K|16GBRAM
| FormZ|C4D
dave62
thx for the new update:)
just one little request: it would be great if the red marked settings are saved in the "deault settings" too.
keep up dave
- Mint 10 64bit nvidia drv 260.19.29/cudatoolkit3.0 intel q6600, 4gbRAM, GTX470 1,2GB
- Mint 10 64bit/ Win7 64bit nvidia drv 260.19.29/cudatoolkit3.2 amd X6, 16gbRAM, 2x GTX580 3GB
->Octane 2.44/ Blender2.5x
Return to “Commercial Product News & Releases (Download here)”
