And then there was light
radiant
Hello guys,
Here is a simple scene i made a while ago.
The only light source is the strings.
I made four to show difference exposers, iso and camera filters.
It was a over night render.
Time:11.21 Hours
Pathtracing
GTX 580
2K downscaled
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
necko77
something is wrong with your glass
ArchiCad, Blender, Moi3d
GTX 580 3GB
Win 7, 64 Bit
lixai
it's refracting like it's filled with glass
Core i7 860, ZOTAC GTX 580 - 3GB, 2 x GTX TITAN, 32Gb RAM
suhail_spa
its acting like a lens..
maybe using a thin layer of glass would help- with low IOR..
good concept btw.. :)
DELL Precision M4500 Laptop (win7 -64bit, Intel core i5 M520 2.4Ghz, 4Gb, Quadro FX880 1Gb, PCI express slot)
with GTX 460 -2GB (running on home-made GPU-expander)
radiant
Yeah, the glass was a quick slap stick specular put on.
and i will add more glare to the strings next time around.
cheers :)
acc24ex
suhail_spa wrote:its acting like a lens..
yes that's the problem, that was already mentioned a couple of times, everything inside the light bulb acts like its filled with glass, that's probably why we need a thin glass shader..
but you have to add another layer inside the light bulb like in real life so it has a thin glass layer.. or change the IOR to soemthing really low.. I know i've been testing out lights inside orbs to get diffuse lights, it's tricky, octane needs more fancy effects for that :)
radiant
Cheers, the render will be improved the next time around
justix
Something similar was posted by me a while ago rising the issue of emitting the wire correctly (glow) like in a real bulb and I see that the new kernel still need to address the issue
http://www.refractivesoftware.com/forum ... 068#p38068
p.s. 11hours? 2XGTX580 ?? seems a very long time to me...
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
