competition entry- work in progress
suhail_spa
this is my WIP for competition entry...
it is based on M.C.Escher's work of 'paradox shapes' or 'impossible objects'.
Being an architect, i was always inspired by Escher...and always wanted to bring together his work somehow...with octane at least it is 'visually' possible and it gave me a chance to finally experiment with it..
- all these solids are 'paradox' or 'impossible' objects and are visually 'correct' only from one angle (and mostly orthographic view). But from any other angle- they are 'juxtaposed' and 'unconnected'
- the challenge here was to being together these paradox objects and align them so that they look visually correct from the POV (which is the image on the left). The image on the right is with a slightly rotated view- where the 'true shapes' are visible. Both these images actually form a part of my competition entry- as they both are equally important. This is the only post-production done here- to join these two images in one slide.
- We have the chessboard as focal point of composition- the chessboard itself is a paradox, and 'real' objects above it only enhances the illusion created by the chessboard..
- the stairs- based on Escher's 'ascending and descending' has snails traling thru them- to enhance visual continuity..(you might have seen these stairs in the movie'inception')
- all other objects float around- like penrose traingle (two types of it), the paradox cube, etc. etc.. cast reflection on the mirrored surface behind them. These reflections show their actual 'juxtaposed' shapes- while from the viewer's POV, they look 'complete'
- the floor of the composition is based on Escher's symmetry drawings- one used here is from the work 'smaller and smaller'..if you look carefully, the same pattern repeats and is interlocked and goes smaller and smaller in a circular fashion..
one can find complete works here- http://www.mcescher.com/
- total approx. 372,000 traingles, modelled/composed on sketchup, few models from 3dwarehouse (free models)
ofcourse there was a lot of thought gone into this composition..even if it doesnt' make it thru the competition (considering the big guns out there)..at least I had fun.. :)
octane window..
octane window..
sketchup window
sketchup window
'paradox'....(work in progress)
DELL Precision M4500 Laptop (win7 -64bit, Intel core i5 M520 2.4Ghz, 4Gb, Quadro FX880 1Gb, PCI express slot)
with GTX 460 -2GB (running on home-made GPU-expander)
PolygonPusher
Thats really cool, I had not started to look that the right image yet and did not read at first and I was really trying to figure out your topolige.
Had me stumped :P
polyon-pushers.org| Flickr| twitter | vimeo
spec: i7 975 3.33ghz | 12 gigs ram | gtx 260 - 195 cuda cores | win 7 64bit | blender 3d | Octane 2.43
IRC: freenode - #blenderchat - #blendercoders - #octanerender
suhail_spa
well thank you
teecee2107
PolygonPusher wrote:...I was really trying to figure out your topolige.
Same for me, i didn't understand how you did this until I saw the two images side by side ...
Really well done ... and 'mind confusing', bravo !
suhail_spa
thank you so much for looking... :)
but considering the other competition entries posted -it is miniscule :oops:
suhail_spa
btw..the final entry is on page 20-
http://www.refractivesoftware.com/forum ... &start=190
it took a lot of time to compose and get the angle correct- so that all the 'escher solids' look complete from the POV...
cheers!
Return to “Works In Progress”
