【BUG】Using Voronoi Fracture crash issue ?!
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
utsuo0606
I'm using Cinema 4D 2027 & Octane Render 2026.6 Build 2.0.3. Using Voronoi Fracture in the scene always causes the entire Cinema 4D to crash. Is there any solution?
_BugReport.zip
(129.89 KiB) Downloaded 5 times
_BugReport.txt
(1.28 MiB) Downloaded 7 times
Sorry, could you share a scene that shows the issue?
I cannot reproduce it here.
ciao,
Beppe
utsuo0606
I can render without issues using C4D 2025, but in versions 2026–2027, the software crashes when using Voronoi Fracture in more complex scenes.
test.zip
(27.37 MiB) Downloaded 11 times
Thanks for sharing the scene.
Please wait for upcoming 2026.6-v2.0.4 version, then merge the scene into a new empty one, and rebuild both Kernel and Render Settings from scratch:
ciao,
Beppe
utsuo0606
I think I’ve found the cause: switching the C4D Color Management setting from ACEScg to an sRGB linear workflow fixed the issue. Is there a way to resolve this properly? Thanks!
Return to “Bug Reports”
