Is there a way to convert Octane materials for Sketchfab?
halvorn_222
Hi everyone!
I’m trying to export some Cinema 4D models with their materials to Sketchfab, but I’ve noticed that my Octane materials don’t come across properly. At the moment I’ve been using basic Standard materials for the upload, but I’d like to create more detailed materials without losing the work I’ve done in Octane.
Is there a way to convert an Octane material into a Cinema 4D Standard or Redshift material? Alternatively, can the complete Octane material be baked into regular texture maps that I can use for export?
For example, I sometimes use Octane’s texture controls to move or scale a texture to a very specific position. Recreating that placement manually with another material can be difficult, especially when the setup contains several nodes.
I’m mainly looking for a practical way to preserve the appearance and UV placement when moving the material to a format that Sketchfab can use.
Any tips or recommended workflow would be greatly appreciated. Thanks!
Pleaser have a look at the following article here:
https://help.otoy.com/hc/en-us/articles/6470112579355-glTF-Scene-Toolkit
And in particular, to "Convert C4D Octane Materials into PBR glTF Materials" paragraph.
ciao,
Beppe
dgydada
The most reliable approach is to bake your Octane materials into texture maps, then export them with your model. This should preserve texture placement more accurately than recreating materials manually. Check whether your Octane setup supports baking the maps you need, such as base color, roughness, and normal maps, before uploading to Sketchfab.
Kovara
This is a common headache, especially with complex Octane setups! Losing all that detailed material work is frustrating. Have you considered baking your Octane materials directly into texture maps?
Return to “OctaneVR Questions & Discussion”
