OctaneRender 2026 for Modo [TEST and STABLE]
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Modo - TEST and STABLE release.
SOLUTIONS TO COMMON ISSUES
  • Make sure your NVIDIA drivers are up to date.
  • Refer to the Troubleshooting section of the manual at https://docs.otoy.com/ModoH/ModoPluginManual.htm#Modo/Troubleshooting.htm
  • Cuda error 999 - failed to load shader code: Multiple definition of 'cpSptStatistics' in 'cuda_teturemode' means that your plugin version is too old for the Nvidia drivers that are installed, so update to the latest version of the plugin.
  • The Octane Greyscale Vertex Attribute is not working for a mesh : make sure Kernel->Render Cache is disabled, and Live Geometry is enabled and Load Cage is disabled for the mesh.
  • How do I copy Meshes between Modo scenes? Please see viewtopic.php?f=34&t=75794&p=389534
Modo Version
Windows : Modo15, 16 and 17 on Window 7, 8 or 10 64bit
OSX : Modo17 on macOS Somona, and only on Apple Silicon
Linux : Modo15, 16 and 17 on 64bit Linux
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 452 or higher on Windows, 450 or higher on Linux.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using.
Support Issues
- Modo version
- OctaneRender for Modo version (ie. 2.0.10.16), and if it is PRIME or STUDIO
- Operating System (ie. Win XP, Vista, 7, 8)
- Amount of RAM
- Nvidia driver version
Prior to reporting issues, please try Modo->System->Open User Folder->Shutdown Modo->then delete the MODO[version].CFG file and restart Modo.
The most important part of resolving a problem is me being able to re-produce that problem. So pls provide as much detail as possible in order for me to do this, and if the problem is specific to the scene, send me the scene.
For more information
- Read the on-line manual, including the FAQ, Troubleshooting Guide and Limitations sections
- Watch the video tutorials at viewtopic.php?f=34&t=59793
- Watch the video tutorials at https://www.youtube.com/channel/UCRCItLUW7oheOp5vCGgkCCw
- Watch the amazing PixelFondue videos at viewtopic.php?f=34&t=59793
- Post your question on this forum thread
Download Links
Important:
  • When the Studio+ version of the plugin is installed, you must disable the Prime version of the plugin when comes with the Modo17 installer. To do this delete the modo\extra\Scripts\OctaneRenderForModoPrime folder from the Modo executable folder.
  • To install the PRIME version,
    1) If you have set the NEXUS_KITDISABLE environment variable to OctaneRender_Prime, delete this environment variable
    2a) On Windows, delete the C:\Program Files\Modo17.1v1.202577\modo\extra\Scripts\OctaneRenderForModoPrime folder
    2b) On macOS, delete the OctaneRenderForModoPrime folder from the Modo17.1 application Contents->Extras->Scripts folder
    2c) On Linux, delete the ~/Modo17.1v1.251515-Release/modo/extra/Scripts/OctaneRenderForModoPrime folder
    3) Install the OctaneRender for Modo PRIME version of the plugin
    4) Ensure you have OctaneRender_Prime plugin DISABLED and the OctaneRender plugin ENABLED in the Modo->System->Kit Toggle Enable menu
  • On macOS, when the 'Octane Improvement Project' dialog shows, press the Enter key to bypass the dialog box.
Current STABLE build (Octane 2026.5)
Previous STABLE build (Octane 2026.4)
Release Notes
2026.5 - v215 (21-Sep-2026)
- Compiled with Octane 2026.5
2026.4.0.213 (16-Jul-2026)
- Compiled with Octane 2026.4
- Fixed issue where .PLY files could not be loaded into the Splat node
- Added the relativeToLxo: tag on the Gaussian Splat and Proxy filenames. For example, if the LXO is in C:\MyScenes and the .ply file is in C:\MyScenes\SceneAssets, then the filename property would be relativeToLxo:SceneAssets/MySplat.ply. Be aware that if you click the Browse button on the Splat or Proxy, the "relativeToLxo:" tage will be replaced by the full file path.
2026.3.0.212 (14-May-2026)
- Compiled with Octane 2026.3
- Added Upsampler Type and Upsampler Source Percentage to the Imager settings
- Removed the AI Light pin from the Kernal settings as per Octane Standalone 2026
- Fixed an Octane error when doing on-the-fly material conversions for Modo non-principled transparent materials (introduced in 2026.2.0.211)
- Fixed an error where on-the-fly material conversions were not setting the Octane "Index of refraction" pin correctly in some situations (introduced in 2026.2.0.211)
2026.2.0.211 (18-Feb-2026)
- Compiled with Octane 2026.2
- Added the Kernel LOD Selection Bias, Neural Radiance Cache and Light Sampler pins
- Fixed issue where setting the Transparency > 60% of a Physically Based Modo Material popped on Octane Log error. A Transparency > 60% results in an Octane Specular material being created - and I am not sure if the material conversion for a Specular material is working as required. Happy to hear feedback from users.
- EXPERIMENTAL: Added the relativeToLxo: tag on the OSL Texture filename. SO for example, if the LXO is in C:\MyScenes and the .oxl file is in C:\MyScenes\SceneAssets, then the filename property would be relativeToLxo:SceneAssets/MyOsl.osl
- Added the "Linear sRGB" option for Texture Image maps as per the Octane 2026.2 release. In practice, I do not think this will be used.
- Added Metalness AOV node as per Octane 2026.2
- Added the Neural Radiance Cache pin to the Photon Tracing Kernel
- Renamed Texture->Image Tiles to UV Tiles to match Octane Standalone
2026.1.0.210 (28-Nov-2025)
- Compiled with Octane 2026.1 - see viewtopic.php?t=85315 for details on this release
- 2026.1 features IN this release : Vectron changes, Gaussian Splats, AOV's (partially), Displacement, OpenPBR surface material node.
- 2026.1 features NOT IN this release : MaterialX, LOD Data, CMYK Halftone texture, Trace sets.
- IMPORTANT: IOR and Anisotropy for all materials are now a texture inputs rather than a float, so scenes from previous versions of Octane will loose their IOR and Anisotropy settings. This applies to the Glossy, Specular, Hair, Metallic, Universal and Specular Materials, and the Metallic and Specular Layers
- The Kernel->LOD Selection Bias and Light Sampler pins did not make it into this release, but will be in the next release.
I have updated that installers at the top of this thread with:
2026.2.0.211
I have updated the installers above with:
2026.3.0.212
rupsty
Hi, I'm using a Mac Studio M1 Ultra with macOS Tahoe 26.2 and Modo 17.1. I'm trying to use your latest build and at first the plugin seems to load ok. But the Octane viewport loads and does nothing. No errors or anything telling me there's a problem. It basically just sits there. Then after searching for remedies and trying deleting certain things, Modo just crashes when I restart.
Is there a way to get this working? I suspect it's Tahoe related. Btw - I'm using the Prime license, not the standalone or anything else.
Thank you,
Rusty
Hi Rusty. There is an issue with the installer. I will get this fixed in the next couple of days and post back here. My apologies for the issue.
rupsty
That would be amazing. Thank you!
Rusty
Hi Rusty
Issuing the following command in a terminal should resolve the issue.
sudo chmod 755 /Library/Application\ Support/Luxology/Content/Kits/OctaneRenderForModo901/resrc
I will need to discuss with OTOY and has this problem resolved in the next release.
rupsty
Ok I'll give it a shot. Thank you!
I have updated the installers at the top of this thread with:
2026.4.0.213
2026.5 - v214
Return to “Foundry Modo”
